[petsc-dev] test harness requires case independent
    Barry Smith
    bsmith at petsc.dev
    Wed Apr 27 13:33:34 CDT 2022
  Scott,
  Could the test harness search for requires be made case independent?
$ make -f gmakefile.test test query='requires' queryval='*superlu_dist*'
Using MAKEFLAGS: -- queryval=*superlu_dist* query=requires
     CLINKER arch-superlu_dist-single/tests/ksp/ksp/tests/ex17
        TEST arch-superlu_dist-single/tests/counts/ksp_ksp_tests-ex17_superlu_dist.counts
 ok ksp_ksp_tests-ex17_superlu_dist
$ make -f gmakefile.test test query='requires' queryval='*SuperLU_DIST*'
Using MAKEFLAGS: -- queryval=*SuperLU_DIST* query=requires
# No test results in  ./arch-superlu_dist-single/tests/counts
I looked query_test.py and could not see where the queryval comes from
Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220427/ef52c5ea/attachment.html>
