[petsc-dev] Can someone help with this failure?
Jacob Faibussowitsch jacob.fai at gmail.com
Mon Sep 27 10:09:03 CDT 2021
TL;DR: don’t use generalized unpacking here:
!2, 3.5 /home/glci/builds-stage1/ytsywSZu/0/petsc/petsc/config/BuildSystem/config/packages/tchem.py
generalized unpacking requires 3.5+
vermin is a python package that checks which python version is required to run a particular python script. Petsc targets python 2.6 or lower and 3.4 or lower, however your change would make python 3.5 the new minimum:
Minimum required versions: 3.5
Incompatible versions: 2
Target versions not met: 2.6-, 3.4-
ctrl-F for “3.5” will find the file and reason in the output.
Best regards,
(Jacob Fai - booss - oh - vitch)
> On Sep 27, 2021, at 10:04, Matthew Knepley <knepley at gmail.com> wrote:
> I do not understand what is being tested or where the failure lies?
>   https://gitlab.com/petsc/petsc/-/jobs/1626183341 <https://gitlab.com/petsc/petsc/-/jobs/1626183341>
>    Thanks,
>      Matt
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210927/9f3c3cf8/attachment.html>
