[petsc-dev] Can someone help with this failure?
Mon Sep 27 10:08:42 CDT 2021
$ vermin -vv  -t=2.6- -t=3.4- config
Minimum required versions: 3.5
!2, 3.5      /home/glci/builds-stage1/ytsywSZu/0/petsc/petsc/config/BuildSystem/config/packages/tchem.py
  generalized unpacking requires 3.5+
Our current min requirements are python-2.6 & 3.4
And tchem.py appears to have python-3.5 code - so this test is failing [for both python2 and python3 requirements]
Satish
On Mon, 27 Sep 2021, Matthew Knepley wrote:
> I do not understand what is being tested or where the failure lies?
>   https://gitlab.com/petsc/petsc/-/jobs/1626183341
>    Thanks,
>      Matt
