[petsc-dev] make test check-test-errors returning $? = 0
Pierre Jolivet pierre at joliv.et
Thu Sep 23 09:08:05 CDT 2021
> On 23 Sep 2021, at 2:14 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Sep 23, 2021 at 5:07 AM Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
> Hello,
> When a tests fails because the timeout limit is reached, check-test-errors still returns a 0 exit code.
> Is this intended? Any way to bypass this and return something different than 0, as it could return false negative in CI tests?
> This is the intended behavior. We ignore timeouts, but report them.
Indeed, I see the failed test in the summary at the end of make test.
That’s no big deal, GitHub workers are slow (or maybe I should stay away from ${DATAFILESPATH}/matrices/arco6), I’ll increase my timeout value for now.
Pierre
> I would not have a problem with a flag to convert these to errors, but I would leave this default.
>   Thanks,
>      Matt
> Thanks,
> Pierre
> $ make -f gmakefile test s='ksp_ksp_tutorials-ex2_1' EXTRA_OPTIONS="-m 200 -n 200" check-test-errors 2>&1 > /dev/null; echo $?
> make: *** [check-test-errors] Error 1
> 2
> $ make -f gmakefile test s='ksp_ksp_tutorials-ex2_1' EXTRA_OPTIONS="-m 200 -n 200" check-test-errors TIMEOUT=1 2>&1 > /dev/null; echo $?
> 0
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210923/9baf5b64/attachment.html>
