[petsc-dev] make test check-test-errors returning $? = 0
Thu Sep 23 07:14:40 CDT 2021
On Thu, Sep 23, 2021 at 5:07 AM Pierre Jolivet <pierre at joliv.et> wrote:
> Hello,
> When a tests fails because the timeout limit is reached, check-test-errors
> still returns a 0 exit code.
> Is this intended? Any way to bypass this and return something different
> than 0, as it could return false negative in CI tests?
This is the intended behavior. We ignore timeouts, but report them.
I would not have a problem with a flag to convert these to errors, but I
would leave this default.
     Matt
> Thanks,
> Pierre
> $ make -f gmakefile test s='ksp_ksp_tutorials-ex2_1' EXTRA_OPTIONS="-m 200
> -n 200" check-test-errors 2>&1 > /dev/null; echo $?
> make: *** [check-test-errors] Error 1
> 2
> -n 200" check-test-errors TIMEOUT=1 2>&1 > /dev/null; echo $?
> 0
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210923/2b76f25e/attachment.html>
