[petsc-dev] Big in MF hessian and BNK?
    Stefano Zampini
    stefano.zampini at gmail.com
    Thu Oct 14 10:19:28 CDT 2021
Alp
I have found this problem, reproducible with release (see below using
src/tao/unconstrained/tutorials/minsurf1)
I was trying MFFD hessian with bntr.
Using assembled hessian is fine
(tf-oneapi) [szampini at localhost tutorials]$ ./minsurf1 -tao_smonitor
-tao_type bntr -mx 10 -my 8 -tao_bnk_max_cg_its 3 -tao_gatol 1.e-4
---- Minimum Surface Area Problem -----
mx: 10     my: 8
iter =   0, Function value 1.45591, Residual: 0.21372
iter =   0, Function value 1.43469, Residual: 0.205909
  iter =   1,   Function value 1.42058,   Residual: 0.0881207
  iter =   2,   Function value 1.41987,   Residual: 0.10019
  iter =   3,   Function value 1.41797,   Residual: 0.0209656
iter =   1, Function value 1.41775, Residual: 0.000288154
  iter =   0,   Function value 1.41775,   Residual: 0.000288154
  iter =   1,   Function value 1.41775,   Residual: 0.000207788
  iter =   2,   Function value 1.41775,   Residual: 0.000123638
  iter =   3,   Function value 1.41775,   Residual: 0.000117563
iter =   2, Function value 1.41775, Residual: < 1.0e-6
Using MFFD hessian error (using bnls segefaults, we should try to check all
possible Tao solvers affected by this bug?)
-tao_mf_hessian
mx: 10     my: 8
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: MatMFFDSetBase() has not been called, this is often caused
by forgetting to call
MatAssemblyBegin/End on the first Mat in the SNES compute function
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.16.0, unknown
[0]PETSC ERROR: ./minsurf1 on a arch-conda-tf-oneapi-single-real named
localhost.localdomain by szampini Thu Oct 14 18:11:23 2021
[0]PETSC ERROR: Configure options
--with-blaslapack-dir=/home/szampini/Devel/miniforge/envs/tf-oneapi
--download-thrust --LDFLAGS=-liomp5 --with-debugging=0 --with-openmp
--with-precision=single --with-fc=0 --download-h2opus --download-slepc
--download-slepc-commit=origin/release
PETSC_ARCH=arch-conda-tf-oneapi-single-real
PETSC_DIR=/home/szampini/Devel/miniforge/Devel/petsc
[0]PETSC ERROR: #1 MatMult_MFFD() at
/home/szampini/Devel/miniforge/Devel/petsc/src/mat/impls/mffd/mffd.c:333
[0]PETSC ERROR: #2 MatMult_Shell() at
/home/szampini/Devel/miniforge/Devel/petsc/src/mat/impls/shell/shell.c:1066
[0]PETSC ERROR: #3 MatMult() at
/home/szampini/Devel/miniforge/Devel/petsc/src/mat/interface/matrix.c:2439
[0]PETSC ERROR: #4 KSP_MatMult() at
/home/szampini/Devel/miniforge/Devel/petsc/include/petsc/private/kspimpl.h:346
[0]PETSC ERROR: #5 KSPCGSolve_STCG() at
/home/szampini/Devel/miniforge/Devel/petsc/src/ksp/ksp/impls/cg/stcg/stcg.c:183
[0]PETSC ERROR: #6 KSPSolve_Private() at
/home/szampini/Devel/miniforge/Devel/petsc/src/ksp/ksp/interface/itfunc.c:914
[0]PETSC ERROR: #7 KSPSolve() at
/home/szampini/Devel/miniforge/Devel/petsc/src/ksp/ksp/interface/itfunc.c:1086
[0]PETSC ERROR: #8 TaoBNKComputeStep() at
/home/szampini/Devel/miniforge/Devel/petsc/src/tao/bound/impls/bnk/bnk.c:477
[0]PETSC ERROR: #9 TaoSolve_BNTR() at
/home/szampini/Devel/miniforge/Devel/petsc/src/tao/bound/impls/bnk/bntr.c:139
[0]PETSC ERROR: #10 TaoSolve() at
/home/szampini/Devel/miniforge/Devel/petsc/src/tao/interface/taosolver.c:227
[0]PETSC ERROR: #11 main() at minsurf1.c:110
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -check_pointer_intensity 0
[0]PETSC ERROR: -mx 10
[0]PETSC ERROR: -my 8
[0]PETSC ERROR: -tao_bnk_max_cg_its 3
[0]PETSC ERROR: -tao_gatol 1.e-4
[0]PETSC ERROR: -tao_mf_hessian
[0]PETSC ERROR: -tao_smonitor
[0]PETSC ERROR: -tao_type bntr
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
Abort(73) on node 0 (rank 0 in comm 0): application called
MPI_Abort(MPI_COMM_WORLD, 73) - process 0
Using fd is fine
-tao_fd_hessian
mx: 10     my: 8
iter =   1, Function value 1.41775, Residual: 0.000342734
  iter =   0,   Function value 1.41775,   Residual: 0.000342734
  iter =   1,   Function value 1.41775,   Residual: 0.000275372
  iter =   2,   Function value 1.41775,   Residual: 0.000148513
  iter =   3,   Function value 1.41775,   Residual: 0.000150663
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211014/4b20f2c7/attachment.html>
