[petsc-dev] Question about the fully implicit Runge-Kutta methods (TS)
    Matthew Knepley
    knepley at gmail.com
    Tue Oct  5 05:43:02 CDT 2021
On Tue, Oct 5, 2021 at 12:42 AM Wang Jingyuan <mc05569 at connect.um.edu.mo>
wrote:
> Dear Sir or Madam,
> I am a student of the University of Macau, I am trying to learn PETSc and
> I have two questions about the TSIRK.
> 1.PETSc 3.16.0 adds “irk" for the TSType and it offers many options like TSIRK1BEE,
> TSIRK2C, TSIRK2D, TSIRK2E, TSIRK3, TSIRKL2,
The types you mention above do not exist. For instance, the first one
"TSIRK1BEE" is actually
https://petsc.org/main/docs/manualpages/TS/TSARKIMEX1BEE.html
>  I am not sure how to use them and if only Gaussian points can be used
> (Radau or Labatto may not offered).
There is currently only one IRK type, which is the Gauss method.
> 2.Maybe there is a similar option to implement the fully implicit
> Runge-Kutta methods in PETSc 3.15 or other previous versions? For example,
> if I want to solve a time dependent problem with a butcher table like
> below, do I need to input it by myself?
> Thank you very much for your help.
I do not understand your question. IRK is only present is 3.16
      Matt
> Best regards,
> Wang Jing-Yuan
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211005/3b41e7c8/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211005/3b41e7c8/attachment-0001.jpeg>
