[petsc-dev] libpetsc.so: undefined references
Antonio T. sagitter sagitter at fedoraproject.org
Sat Oct 2 07:48:34 CDT 2021
Hi all.
In PETSc-3.16.0, the linker is not working because of these undefined
references (see https://pastebin.com/izGTfmMp):
/usr/bin/ld: x86_64/lib/libpetsc.so: undefined reference to `operator
delete(void*, unsigned long)'
/usr/bin/ld: x86_64/lib/libpetsc.so: undefined reference to `__cxa_rethrow'
`__gxx_personality_v0'
new(unsigned long)'
`std::__throw_bad_alloc()'
`std::terminate()'
`std::__throw_bad_array_new_length()'
/usr/bin/ld: x86_64/lib/libpetsc.so: undefined reference to `typeinfo
for std::exception'
`__cxa_begin_catch'
`__cxa_end_catch'
`std::__throw_length_error(char const*)'
collect2: error: ld returned 1 exit status
There are also
$ ldd -r build/BUILD/petsc-3.16.0/petsc-3.16.0/x86_64/lib/libpetsc.so'
Start: shell
	linux-vdso.so.1 (0x00007fffbf347000)
	libsuperlu.so.5.2 => /lib64/libsuperlu.so.5.2 (0x00007f00dad0c000)
	libflexiblas.so.3 => /lib64/libflexiblas.so.3 (0x00007f00da95a000)
	libcgns.so.4.2 => /lib64/libcgns.so.4.2 (0x00007f00da873000)
	libhdf5.so.103 => /lib64/libhdf5.so.103 (0x00007f00da4d8000)
	libm.so.6 => /lib64/libm.so.6 (0x00007f00da3f8000)
	libX11.so.6 => /lib64/libX11.so.6 (0x00007f00da2ae000)
	libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f00da294000)
	libc.so.6 => /lib64/libc.so.6 (0x00007f00da08b000)
	libgfortran.so.5 => /lib64/libgfortran.so.5 (0x00007f00d9dde000)
	libquadmath.so.0 => /lib64/libquadmath.so.0 (0x00007f00d9d94000)
	/lib64/ld-linux-x86-64.so.2 (0x00007f00dc18b000)
	libsz.so.2 => /lib64/libsz.so.2 (0x00007f00d9d8a000)
	libz.so.1 => /lib64/libz.so.1 (0x00007f00d9d6e000)
	libxcb.so.1 => /lib64/libxcb.so.1 (0x00007f00d9d43000)
	libXau.so.6 => /lib64/libXau.so.6 (0x00007f00d9d3d000)
undefined symbol: _ZTISt9exception
(build/BUILD/petsc-3.16.0/petsc-3.16.0/x86_64/lib/libpetsc.so)
undefined symbol: __gxx_personality_v0
undefined symbol: _ZdlPvm
undefined symbol: __cxa_rethrow
undefined symbol: _Znwm
undefined symbol: _ZSt17__throw_bad_allocv
undefined symbol: _ZSt9terminatev
undefined symbol: _ZSt28__throw_bad_array_new_lengthv
undefined symbol: __cxa_begin_catch
undefined symbol: __cxa_end_catch
undefined symbol: _ZSt20__throw_length_errorPKc
I'm attaching configure.log and make.log
Antonio Trande
Fedora Project
mailto: sagitter at fedoraproject.org
GPG key: 0x29FBC85D7A51CC2F
GPG key server: https://keyserver1.pgp.com/
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211002/27c8815b/attachment-0001.zip>
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211002/27c8815b/attachment-0001.bin>
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211002/27c8815b/attachment-0001.sig>
