[petsc-dev] I am getting this error ...
    Mark Adams
    mfadams at lbl.gov
    Thu Nov  4 16:44:56 CDT 2021
It gets a lot further.
On Thu, Nov 4, 2021 at 5:32 PM Mark Adams <mfadams at lbl.gov> wrote:
> OK, sorry I missed the CPPFLAGS. It is running now.
> Thanks,
> On Thu, Nov 4, 2021 at 4:43 PM Satish Balay <balay at mcs.anl.gov> wrote:
>> Multiple e-mail threads on the same issue (:
>> As suggested in my earlier thread - add -mp=gpu to both CPPFLAGS and
>> CFLAGS [or LDFLAGS]
>> Satish
>> Executing: cc  -o /tmp/petsc-Vvs8_T/config.setCompilers/conftest   -g
>> -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4
>> /tmp/petsc-Vvs8_T/config.setCompilers/conftest.o
>> Possible ERROR while running linker:
>> stderr:
>> nvc-Warning-The -gpu option has no effect unless a language-specific
>> option to enable GPU code generation is used (e.g.: -acc, -mp=gpu, -stdpar,
>> -cuda)
>> On Thu, 4 Nov 2021, Mark Adams wrote:
>> > It is CPPFLAGS. I seem to get the same behavior.
>> > FWIW, I did get this response from NERSc but I don't know how to
>> interpret
>> > it.
>> > He seems to be saying that I don't need -mp=gpu for the device compiler
>> > (nvcc). He seems to think that I am adding -gpu.
>> > nvcc -- The device compiler does not need any of those flags because it
>> > already knows that it's being fed cuda code. The warning you're seeing
>> is
>> > coming from nvc (which is the host / CPU side compiler) if you're in the
>> > PrgEnv-nvidia environment. You should not need to add -mp=gpu and -cuda,
>> > please just add the -cuda flag (to your host code) not to the device
>> code.
>> > I will try to talk with this guy again.
>> > Thanks,
>> > On Thu, Nov 4, 2021 at 4:11 PM Barry Smith <bsmith at petsc.dev> wrote:
>> > >   Yes, you need to use the CPPFLAGS which maybe called CPPCFLAGS I am
>> not
>> > > sure
>> > > On Nov 4, 2021, at 3:23 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> > > Ah, CCFLAGS does not seem to work.
>> > > On Thu, Nov 4, 2021 at 3:07 PM Barry Smith <bsmith at petsc.dev> wrote:
>> > >>   You have to pass in the flag to turn off the bitching about -gpu
>> to the
>> > >> C preprocessor, not the C compiler.
>> > >> stderr:
>> -stdpar,
>> > >> -cuda)
>> > >> Source:
>> > >> #include "confdefs.h"
>> > >> #include "conffix.h"
>> > >> #include <stdlib.h>
>> > >> > On Nov 4, 2021, at 2:49 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> > >> > on Perlmutter with nvhpc:
>> > >> >               Defined make macro "CPP" to "cc --use cpp32"
>> > >> > Preprocessing source:
>> > >> > #include <stdlib.h>
>> > >> > Executing: cc --use cpp32  -I/tmp/petsc-jV9U1b/config.setCompilers
>> > >> /tmp/petsc-jV9U1b/config.setCompilers/conftest.c
>> > >> > Possible ERROR while running preprocessor: exit code 1
>> > >> > stderr:
>> > >> > nvc-Error-Unknown switch: --use
>> > >> > Source:
>> > >> > <configure.log>
>> > >> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211104/b793b559/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211104/b793b559/attachment-0001.obj>
