[petsc-dev] I am getting this error ...
Mark Adams
mfadams at lbl.gov
Thu Nov 4 16:32:14 CDT 2021
OK, sorry I missed the CPPFLAGS. It is running now.
On Thu, Nov 4, 2021 at 4:43 PM Satish Balay <balay at mcs.anl.gov> wrote:
> Multiple e-mail threads on the same issue (:
> As suggested in my earlier thread - add -mp=gpu to both CPPFLAGS and
> CFLAGS [or LDFLAGS]
> Satish
> Executing: cc -o /tmp/petsc-Vvs8_T/config.setCompilers/conftest -g
> -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4
> /tmp/petsc-Vvs8_T/config.setCompilers/conftest.o
> Possible ERROR while running linker:
> stderr:
> nvc-Warning-The -gpu option has no effect unless a language-specific
> option to enable GPU code generation is used (e.g.: -acc, -mp=gpu, -stdpar,
> -cuda)
> On Thu, 4 Nov 2021, Mark Adams wrote:
> > It is CPPFLAGS. I seem to get the same behavior.
> > FWIW, I did get this response from NERSc but I don't know how to
> interpret
> > it.
> > He seems to be saying that I don't need -mp=gpu for the device compiler
> > (nvcc). He seems to think that I am adding -gpu.
> > nvcc -- The device compiler does not need any of those flags because it
> > already knows that it's being fed cuda code. The warning you're seeing is
> > coming from nvc (which is the host / CPU side compiler) if you're in the
> > PrgEnv-nvidia environment. You should not need to add -mp=gpu and -cuda,
> > please just add the -cuda flag (to your host code) not to the device
> code.
> > I will try to talk with this guy again.
> > Thanks,
> > On Thu, Nov 4, 2021 at 4:11 PM Barry Smith <bsmith at petsc.dev> wrote:
> > > Yes, you need to use the CPPFLAGS which maybe called CPPCFLAGS I am
> not
> > > sure
> > > On Nov 4, 2021, at 3:23 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > Ah, CCFLAGS does not seem to work.
> > > On Thu, Nov 4, 2021 at 3:07 PM Barry Smith <bsmith at petsc.dev> wrote:
> > >> You have to pass in the flag to turn off the bitching about -gpu to
> the
> > >> C preprocessor, not the C compiler.
> > >> stderr:
> -stdpar,
> > >> -cuda)
> > >> Source:
> > >> #include "confdefs.h"
> > >> #include "conffix.h"
> > >> #include <stdlib.h>
> > >> > On Nov 4, 2021, at 2:49 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > >> > on Perlmutter with nvhpc:
> > >> > Defined make macro "CPP" to "cc --use cpp32"
> > >> > Preprocessing source:
> > >> > #include <stdlib.h>
> > >> > Executing: cc --use cpp32 -I/tmp/petsc-jV9U1b/config.setCompilers
> > >> /tmp/petsc-jV9U1b/config.setCompilers/conftest.c
> > >> > Possible ERROR while running preprocessor: exit code 1
> > >> > stderr:
> > >> > nvc-Error-Unknown switch: --use
> > >> > Source:
> > >> > <configure.log>
> > >> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211104/cd8830b6/attachment.html>
