[petsc-dev] invocation of nvcc
Satish Balay
balay at mcs.anl.gov
Thu Nov 4 12:40:52 CDT 2021
I think we went through this issue before.
nvc is the 'c' compiler. And for some reason its giving 'cuda' warnings.
I think you might have switched progenv last time [and avoided this compiler]
You can try using this compiler manually - on simple code - and then seek help from the admins on how to avoid these warnings..
Satish
- create test.c with:
#include <stdlib.h>
compile (or preporcess):
cc -E test.c
- You should get:
stderr:
nvc-Warning-The -gpu option has no effect unless a language-specific option to enable GPU code generation is used (e.g.: -acc, -mp=gpu, -stdpar, -cuda)
Now provide this info to the machine admins [or nvidia folk] - and ask how to get rid of this message.
Satish
On Thu, 4 Nov 2021, Mark Adams wrote:
> Correction it is nvc:
> And I add -mp=gpu to CUDAFLAGS
> > > Does anyone know if PETSc calls nvcc and hence can add flags to the
> > > invocation? nvcc wants a flag like -mp=gpu but I don't know if we do that
> > > or a compiler wrapper in the environment.
> > $ ./configure --help |grep CUDA
> > <snip>
> > --CUDAC=<prog>
> > Specify the CUDA compiler
> > --CUDAFLAGS=<string>
> > Specify the CUDA compiler options
> > <snip>
> > Satish
