[petsc-dev] invocation of nvcc
    Mark Adams
    mfadams at lbl.gov
    Thu Nov  4 12:28:55 CDT 2021
Correction it is nvc:
nvc-Warning-The -gpu option has no effect unless a language-specific option
to enable GPU code generation is used (e.g.: -acc, -mp=gpu, -stdpar, -cuda)
And I add  -mp=gpu to CUDAFLAGS
On Thu, Nov 4, 2021 at 1:09 PM Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 4 Nov 2021, Mark Adams wrote:
> > Does anyone know if PETSc calls nvcc and hence can add flags to the
> > invocation? nvcc wants a flag like -mp=gpu but I don't know if we do that
> > or a compiler wrapper in the environment.
> $ ./configure --help |grep CUDA
> <snip>
>   --CUDAC=<prog>
>        Specify the CUDA compiler
>   --CUDAFLAGS=<string>
>        Specify the CUDA compiler options
> <snip>
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211104/2696a89e/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211104/2696a89e/attachment-0001.obj>
