[petsc-dev] [petsc-users] strange segv
    Mark Adams
    mfadams at lbl.gov
    Sat May 29 21:50:27 CDT 2021
And I grief using gcc-8.1.1 and get this error:
/autofs/nccs-svm1_sw/summit/gcc/8.1.1/include/c++/8.1.1/type_traits(347):
error: identifier "__ieee128" is undefined
Any ideas?
On Sat, May 29, 2021 at 10:39 PM Mark Adams <mfadams at lbl.gov> wrote:
> And  valgrind sees this. I think the jump to the function is going to the
> wrong place.
> I'm giving up on PGI but can try newer versions of GCC. (what is the deal
> with the range of major releases, 4-10?)
> (as I said this looks like an error that a user is getting so I'd like to
> figure it out).
>     0 SNES Function norm 4.974994975313e-03
> ==77820== Invalid read of size 4
> ==77820==    at 0x7E69068: LandauKokkosJacobian (in
> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/lib/libpetsc.so.3.015.0)
> ==77820==    by 0x7C598AF: LandauFormJacobian_Internal (plexland.c:212)
> ==77820==    by 0x7C728D3: LandauIJacobian (plexland.c:2107)
> ==77820==    by 0x7C8C26B: TSComputeIJacobian (ts.c:934)
> ==77820==    by 0x7E28337: SNESTSFormJacobian_Theta (theta.c:1007)
> ==77820==    by 0x7CBBFD3: SNESTSFormJacobian (ts.c:4415)
> ==77820==    by 0x7AD84BF: SNESComputeJacobian (snes.c:2824)
> ==77820==    by 0x7BA945B: SNESSolve_NEWTONLS (ls.c:222)
> ==77820==    by 0x7AF336F: SNESSolve (snes.c:4769)
> ==77820==    by 0x7E19D13: TSTheta_SNESSolve (theta.c:185)
> ==77820==    by 0x7E1A8B7: TSStep_Theta (theta.c:223)
> ==77820==    by 0x7CB093F: TSStep (ts.c:3571)
> ==77820==  Address 0x96fff690 is in a --- anonymous segment
> ==77820==
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> X to find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR: The EXACT line numbers in the error traceback are not
> available.
> [0]PETSC ERROR: instead the line number of the start of the function is
> given.
> [0]PETSC ERROR: #1 LandauKokkosJacobian() at
> /gpfs/alpine/csc314/scratch/adams/petsc/src/ts/utils/dmplexlandau/kokkos/landau.kokkos.cxx:272
> On Sat, May 29, 2021 at 8:46 PM Mark Adams <mfadams at lbl.gov> wrote:
>> On Sat, May 29, 2021 at 7:48 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>    I don't see why it is not running the Kokkos check. Here is the rule
>>> right below the CUDA rule that is apparently running.
>>> check_build:
>>>         - at echo "Running check examples to verify correct installation"
>>>         - at echo "Using PETSC_DIR=${PETSC_DIR} and
>>> PETSC_ARCH=${PETSC_ARCH}"
>>>         + at cd src/snes/tutorials >/dev/null; ${OMAKE_SELF}
>>> PETSC_ARCH=${PETSC_ARCH}  PETSC_DIR=${PETSC_DIR} clean-legacy
>>> PETSC_ARCH=${PETSC_ARCH}  PETSC_DIR=${PETSC_DIR} testex19
>>>         + at if [ "${HYPRE_LIB}" != "" ] && [ "${PETSC_WITH_BATCH}" = "" ]
>>> &&  [ "${PETSC_SCALAR}" = "real" ]; then \
>>> DIFF=${PETSC_DIR}/lib/petsc/bin/petscdiff runex19_hypre; \
>>>          fi;
>>>         + at if [ "${CUDA_LIB}" != "" ] && [ "${PETSC_WITH_BATCH}" = "" ]
>>> DIFF=${PETSC_DIR}/lib/petsc/bin/petscdiff runex19_cuda; \
>>>          fi;
>>>         + at if [ "${KOKKOS_KERNELS_LIB}" != "" ] && [
>>> "${PETSC_WITH_BATCH}" = "" ] &&  [ "${PETSC_SCALAR}" = "real" ] && [
>>> "${PETSC_PRECISION}" = "double" ] && [ "${MPI_IS_MPIUNI}" = "0" ]; then \
>>> DIFF=${PETSC_DIR}/lib/petsc/bin/petscdiff runex3k_kokkos; \
>>>          fi;
>>>   Regarding the debugging, if it is just one MPI rank (or even more)
>>> with GDB it will trap the error and show the exact line of source code
>>> where the error occurred and you can poke around at variables to see if
>>> they look corrupt or wrong (for example crazy address in a pointer), I
>>> don't know why your debugger is not giving more useful information.
>> This is what I did (in DDT). It stopped at the function call and the data
>> looked fine. I stepped into the call, but didn't get to it. The signal
>> handler was called and I was dead.
>> Maybe I did something in my branch. Can't see what, but I keep probing,
>> Thanks,
>>>   Barry
>>> > On May 29, 2021, at 2:16 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> > I am running on Summit with Kokkos-CUDA and I am getting a segv that
>>> looks like some sort of a compile/link mismatch. I also have a user with a
>>> C++ code that is getting strange segvs when calling MatSetValues with CUDA
>>> (I know MatSetValues is not a cupsarse method, but that is the report that
>>> I have). I have no idea if these are related but they both involve C -- C++
>>> calls ...
>>> > I started with a clean build (attached) and I ran in DDT. DDT stopped
>>> at the call in plexland.c to the KokkosLanau operator. I stepped into this
>>> function and then took this screenshot of the stack, with the Kokkos call
>>> and PETSc signal handler.
>>> > Make check does not seem to be running Kokkos tests:
>>> > 15:02 adams/landau-mass-opt *=
>>> /gpfs/alpine/csc314/scratch/adams/petsc$ make
>>> PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc
>>> PETSC_ARCH=arch-summit-opt-gnu-kokkos-notpl-cuda10 check
>>> > Using PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc and
>>> > C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI
>>> process
>>> > C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>>> processes
>>> > C/C++ example src/snes/tutorials/ex19 run successfully with cuda
>>> > Completed test examples
>>> > Also, I ran this AM with another branch that had not been rebased with
>>> main as recently as this branch (adams/landau-mass-opt).
>>> > Any ideas?
>>> > <make.log><configure.log><Screen Shot 2021-05-29 at 2.51.00 PM.png>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210529/752c6a25/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210529/752c6a25/attachment-0001.obj>
