[petsc-dev] Problem with the reorganization of complex with clang
Matthew Knepley
knepley at gmail.com
Thu May 13 13:14:35 CDT 2021
In this CI run (linux-clang-avg):
https://gitlab.com/petsc/petsc/-/jobs/1260342204
The compile fails building a C++ file, demangle.cxx. It fails at the first
line,
including <petsc/private/petscimpl.h>, down in petscsystypes.h. It bombs
during the definition of complex because it looks like the compiler is not
defining __cplusplus, and thus takes the wrong branch. Is this what is
happening?
I cannot access this machine.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210513/216c2c11/attachment.html>
