[petsc-dev] Strange issue with testsuite
    Stefano Zampini
    stefano.zampini at gmail.com
    Thu May 13 05:48:08 CDT 2021
Scott
I found the issue. The programname on this machine has the fullpath,
including a matching pattern for the egrep rule.
Thanks
Il giorno mer 12 mag 2021 alle ore 22:33 Scott Kruger <kruger at txcorp.com>
ha scritto:
> It's something like this:
> cd
> arch-debug-uni/tests/sys/tests/runex54_1_options_file-ex54options_1a_wrong/
> cat  *.tmp       #  Does anything look fishy?
> cat diff*.sh     # see how diff test with filter is being setup by harness
> ./diff*.sh       # run the diff test
> Hopefully you can see what's the problem is in more detail.  These error
> catching tests are tricker to debug than the normal tests.
> Scott
> On 2021-05-12 16:48, Stefano Zampini did write:
> > I'm currently trying to build PETSc on a NEC-SX. Apart from other issues,
> > I'm facing the following issue with the testsuite.
> > [zampins at stork petsc]$ make test s='sys*ex54*1a*' V=1
> > Using MAKEFLAGS: -- V=1 s=sys*ex54*1a*
> arch-debug-uni/tests/sys/tests/runex54_1_options_file-ex54options_1a_wrong.sh
> >  -v
> >  ok sys_tests-ex54_1_options_file-ex54options_1a_wrong #
> > /home/zampins/src/petsc/lib/petsc/bin/petsc-mpiexec.uni  -n 1 ../ex54
> > -options_left 0 -options_view -options_file ex54options_1a_wrong  2>&1 |
> > cat > ex54_1_options_file-ex54options_1a_wrong.tmp
> > not ok diff-sys_tests-ex54_1_options_file-ex54options_1a_wrong # Error
> > code: 1
> > # 1a2
> > # > [0]PETSC ERROR:
> /home/zampins/src/petsc/arch-debug-uni/tests/sys/tests/runex54_1_options_file-ex54options_1a_wrong/../ex54
> > on a arch-debug-uni named stork by zampins Wed May 12 16:45:46 2021
> > However, if I run the test directly, I think it produces the proper
> output
> > to be filtered. How can I debug this?
> > [zampins at stork tests]$ ./ex54 -options_left 0 -options_view
> -options_file
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Invalid argument
> > [0]PETSC ERROR: Unknown first token in options file ex54options_1a_wrong
> > line 1: !
> > [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> > for trouble shooting.
> > [0]PETSC ERROR: Petsc Development GIT revision: v3.15.0-298-g2115278b7a
> >  GIT Date: 2021-05-12 14:01:17 +0300
> > [0]PETSC ERROR: ./ex54 on a arch-debug-uni named stork by zampins Wed May
> > 12 16:46:21 2021
> > [0]PETSC ERROR: Configure options --FC_LINKER_FLAGS="-Wl,-z -Wl,muldefs"
> > --download-sowing-configure-arguments="CC=ncc CXX=nc++"
> --with-blaslapack-lib="[/opt/nec/ve/nlc/2.3.0/lib/liblapack.a,/opt/nec/ve/nlc/2.3.0/lib/libblas_sequential.a]"
> > --with-cc=ncc --with-cxx=nc++ --with-debugging=1 --with-fc=nfort
> > --with-mpi=0 --with-shared-ld=nld --with-shared-libraries=1
> > PETSC_ARCH=arch-debug-uni
> > [0]PETSC ERROR: #1 PetscOptionsInsertFilePetsc() at
> > /home/zampins/src/petsc/src/sys/objects/options.c:537
> > [0]PETSC ERROR: #2 PetscOptionsInsertFile() at
> > /home/zampins/src/petsc/src/sys/objects/options.c:645
> > [0]PETSC ERROR: #3 PetscOptionsInsertArgs() at
> > /home/zampins/src/petsc/src/sys/objects/options.c:684
> > [0]PETSC ERROR: #4 PetscOptionsInsert() at
> > /home/zampins/src/petsc/src/sys/objects/options.c:907
> > [0]PETSC ERROR: #5 PetscInitialize() at
> > /home/zampins/src/petsc/src/sys/objects/pinit.c:1024
> > Stefano
> Scott Kruger
> Tech-X Corporation               kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
> Boulder, CO 80303                Fax:   (303) 448-7756
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210513/ac43972f/attachment.html>
