[petsc-dev] Error of petsc-3.15 with python-3.10
Antonio T. sagitter
sagitter at fedoraproject.org
Wed May 12 04:51:19 CDT 2021
Hi all.
I'm sorry if using python-3.10 is not in your plan yet and this mail is
inappropriate now.
This is an error from a build of PETSc-3.15 in a Python-3.10.0b1 (on
Fedora 35
, GCC-11.1.1):
+ make V=1 MAKE_NP=2
PETSC_DIR=/builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0
PETSC_ARCH=x86_64 all
/usr/bin/python3 ./config/gmakegen.py --petsc-arch=x86_64
/builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/./config/gmakegen.py:4:
DeprecationWarning: The distutils package is deprecated and slated for
removal in Python 3.12. Use setuptools or check PEP 632 for potential
alternatives
from distutils.sysconfig import parse_makefile
DeprecationWarning: The distutils.sysconfig module is deprecated, use
sysconfig instead
Traceback (most recent call last):
File
"/builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/./config/gmakegen.py",
line 345, in <module>
main(petsc_arch=opts.petsc_arch, pkg_dir=opts.pkg_dir,
pkg_name=opts.pkg_name, pkg_arch=opts.pkg_arch, pkg_pkgs=opts.pkg_pkgs,
output=opts.output, verbose=opts.verbose)
File
line 328, in main
petsc.summary()
File
line 255, in summary
self.mistakes.summary()
File
line 79, in summary
raise RuntimeError('PETSc makefiles contain mistakes or files are
missing on filesystem.\n%s\nPossible reasons:\n\t1. Files were deleted
locally, try "hg revert filename" or "git checkout filename".\n\t2.
Files were deleted from repository, but were not removed from makefile.
Send mail to petsc-maint at mcs.anl.gov.\n\t3. Someone forgot to "add" new
files to the repository. Send mail to petsc-maint at mcs.anl.gov.' %
('\n'.join(self.mistakes)))
RuntimeError: PETSc makefiles contain mistakes or files are missing on
filesystem.
Makefile contains directory not on filesystem:
/builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/src/sys: ['\\']
/builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/src/mat/impls/aij/seq:
/builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/src/ksp/ksp/impls: ['\\']
/builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/src/ksp/pc/impls: ['ml\\']
/builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/src/tao/complementarity/impls:
['#', 'isls', 'rscs']
Possible reasons:
1. Files were deleted locally, try "hg revert filename" or "git
checkout filename".
2. Files were deleted from repository, but were not removed from
makefile. Send mail to petsc-maint at mcs.anl.gov.
3. Someone forgot to "add" new files to the repository. Send mail to
gmakefile:67: x86_64/lib/petsc/conf/files: No such file or directory
Can you say me what's cause it? (Same configuration works with Python-3.9)?
Regards.
Antonio Trande
Fedora Project
mailto: sagitter at fedoraproject.org
GPG key: 0x29FBC85D7A51CC2F
GPG key server: https://keys.gnupg.net/
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210512/11c70cfa/attachment-0003.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210512/11c70cfa/attachment-0004.bin>
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210512/11c70cfa/attachment-0005.bin>
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210512/11c70cfa/attachment-0001.sig>
