[petsc-dev] should plexgeometry.c check for divide by zero?
Barry Smith bsmith at petsc.dev
Sun May 9 11:06:45 CDT 2021
  Matt,
  if (centroid) for (d = 0; d < dim; ++d) centroid[d] /= (vsum*4);
   csum[d] /= (tdim+1)*vsum;
  Also
  for (d = 0; d < dim; d++) n[d] /= norm;
  etc
  Would adding (some/all) tests detect errors in the geometry information earlier then later strange behavior that happens because of the infinities in the arrays?
