[petsc-dev] Compiling issue with main branch
Barry Smith bsmith at petsc.dev
Thu May 6 11:59:41 CDT 2021
https://gitlab.com/petsc/petsc/-/merge_requests/3958 <https://gitlab.com/petsc/petsc/-/merge_requests/3958>
> On May 6, 2021, at 11:57 AM, Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> Wack a mole with our approach of configure treating linker warnings as errors [aka -Werror]
> Satish
> diff --git a/config/BuildSystem/config/framework.py b/config/BuildSystem/config/framework.py
> index 968071d995..689f0c4ee5 100644
> --- a/config/BuildSystem/config/framework.py
> +++ b/config/BuildSystem/config/framework.py
> @@ -547,6 +547,7 @@ class Framework(config.base.Configure, script.LanguageProcessor):
>       lines = [s for s in lines if s.find('may conflict with libgfortran') < 0]
>       # MacOS libraries built for different MacOS versions
>       lines = [s for s in lines if s.find(' was built for newer macOS version') < 0]
> +      lines = [s for s in lines if s.find(' was built for newer OSX version') < 0]
>       if lines: output = '\n'.join(lines)
>       else: output = ''
>       self.log.write("Linker output after filtering:\n"+output+":\n")
> On Thu, 6 May 2021, Jacob Faibussowitsch wrote:
>> Guess who’s back:
>> ld: warning: object file (/Users/kongf/projects/petsc1/arch-darwin-c-opt/lib/libfblas.a(ddot.o)) was built for newer OSX version (10.14) than being linked (10.9)
>> Best regards,
>> (Jacob Fai - booss - oh - vitch)
>>> On May 6, 2021, at 12:43, Fande Kong <fdkong.jd at gmail.com> wrote:
>>> Hi All,
>>> I could compile 3.15.0, but could not compile the main branch using the same environment.
>>> If you need me to do git bisect, please let me know.
>>> The log was attached.
>>> Fande
>>> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210506/33c5cada/attachment.html>
