[petsc-dev] Compiling issue with main branch
Fande Kong
fdkong.jd at gmail.com
Thu May 6 11:43:12 CDT 2021
Hi All,
I could compile 3.15.0, but could not compile the main branch using the
same environment.
If you need me to do git bisect, please let me know.
The log was attached.
Fande
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210506/cbbac3b4/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210506/cbbac3b4/attachment-0001.obj>
