[petsc-dev] where is DATAFILESPATH ?
    Satish Balay
    balay at mcs.anl.gov
    Wed Mar 31 13:39:08 CDT 2021
The repo is at https://gitlab.com/petsc/datafiles
If a clone is located in ~/ - configure will look for it and use it. Otherwise one can specify with DATAFILESPATH=loc configure option
Satish
On Wed, 31 Mar 2021, Eric Chamberland wrote:
> Hi,
> looking at petsc tests launched from "make test", I see many tests are skipped
> like this:
> ok ksp_ksp_tutorials-ex76_1 # SKIP Requires DATAFILESPATH
>         TEST
>         arch-linux-c-debug/tests/counts/ksp_ksp_tutorials-ex76_geneo_pc_hpddm_levels_1_eps_nev-5.counts
> But where can I find the repository containing the data for these tests?...
> Or what is the right value for DATAFILESPATH?
> Thanks,
> Eric
