[petsc-dev] reproducing crashes in the test harness
Matthew Knepley
knepley at gmail.com
Tue Mar 30 06:32:54 CDT 2021
On Tue, Mar 30, 2021 at 6:52 AM Pierre Jolivet <pierre at joliv.et> wrote:
> On 30 Mar 2021, at 12:37 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Mar 30, 2021 at 12:25 AM Barry Smith <bsmith at petsc.dev> wrote:
>> # FAILED snes_tutorials-ex12_quad_hpddm_reuse_threshold
>> snes_tutorials-ex12_p4est_nc_singular_2d_hpddm snes_tutorials-ex56_hpddm
>> snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij sys_tests-ex53_2
>> snes_tutorials-ex12_quad_hpddm_reuse_baij
>> snes_tutorials-ex12_p4est_singular_2d_hpddm
>> snes_tutorials-ex12_tri_parmetis_hpddm
>> snes_tutorials-ex12_quad_singular_hpddm sys_tests-ex26_1 sys_tests-ex26_2
>> snes_tutorials-ex12_tri_parmetis_hpddm_baij
>> snes_tutorials-ex12_tri_hpddm_reuse_baij snes_tutorials-ex12_tri_hpddm_reus
>> Scott,
>> Any thoughts on how the test harness could tell the developer exactly
>> how to reproduce a problematic cases in the debugger without them digging
>> around in the code to check arguments etc.
>> So for example "Run: mpiexec -n N ./xxx args -start_in_debugger" to
>> reproduce this problem? Then one could just cut and paste and be debugging
>> away.
> I always just EXTRA_ARGUMENTS="-start_in_debugger". However, if you really
> want to run standalone, V=1 will display the args I think
> I don’t think it does.
> It displays the path of the .sh script being invoked, but then you have to
> decipher that as well.
> Also, when there are failures on workers such as diff-test+param, you
> can’t copy/paste that directly in $PETSC_ARCH/tests/echofailures.sh, you
> have to filter out the diff- and +param part, which is not very practical I
> think.
True. I am also not able to reproduce just part of a param test. I need to
run all of them.
THanks,
Matt
> Thanks,
> Pierre
> Thanks,
> Matt
>> Thanks
>> Barry
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210330/c5b3cf98/attachment.html>
