[petsc-dev] Petsc "make test" have more failures for --with-openmp=1
Matthew Knepley
knepley at gmail.com
Fri Mar 19 07:47:36 CDT 2021
On Fri, Mar 19, 2021 at 7:30 AM Lawrence Mitchell <wence at gmx.li> wrote:
> > On 19 Mar 2021, at 03:51, Jed Brown <jed at jedbrown.org> wrote:
> > It's a notable weakness of DMPlex that it does not apply such an
> ordering of dofs and I've complained to Matt about it many times over the
> years, but any blame rests solely with me for not carving out time to
> implement it here.
> I think there is a way to do this with plex (at least we do it), like so:
> DMPlexGetOrdering(dm, MATORDERINGRCM, NULL, &isperm);
> you might need to then invert this ordering.
> Now when you make a section you either say
> PetscSectionSetPermutation(section, isperm);
You can do that if you only want to permute the dofs, but usually I want to
reorder everything so that any Section comes out right
DMPlexPermute()
Matt
> before PetscSectionSetup(section);
> or, if you're using DMPlexCreateSection, pass in the isperm
> This gives RCM-based ordering for the dof numbering of the section.
> Cheers,
> Lawrence
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210319/84e9e4a4/attachment.html>
