[petsc-dev] Petsc "make test" have more failures for --with-openmp=1
    Lawrence Mitchell
    wence at gmx.li
    Fri Mar 19 06:30:01 CDT 2021
> On 19 Mar 2021, at 03:51, Jed Brown <jed at jedbrown.org> wrote:
> It's a notable weakness of DMPlex that it does not apply such an ordering of dofs and I've complained to Matt about it many times over the years, but any blame rests solely with me for not carving out time to implement it here.
I think there is a way to do this with plex (at least we do it), like so:
DMPlexGetOrdering(dm, MATORDERINGRCM, NULL, &isperm);
you might need to then invert this ordering.
Now when you make a section you either say
PetscSectionSetPermutation(section, isperm);
before PetscSectionSetup(section);
or, if you're using DMPlexCreateSection, pass in the isperm
This gives RCM-based ordering for the dof numbering of the section.
Cheers,
Lawrence
