[petsc-dev] Case TS005062693 - XLF: ICE in xlfentry compiling a module with 358 subroutines
Tue Mar 16 14:05:27 CDT 2021
On Tue, Mar 16, 2021 at 2:42 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
wrote:
> To me the best solution is to first split the files when possible (it is
> often not or just too painful) and then adding imports if needed.
> I’m not sure I agree. Bear in mind my familiarity with fortran is very
> limited, but to me the “use” statement is similar to #include <header> in C
> or using namespace xxx in cpp.
> Our fortran interface is not optimal code atm, it’s as if we put a
>  "#include <petscvec.h>” before every Vec function in the C source
> (assuming include guards are not used). Sure you can fix this by splitting
> the vec src files in two, but at the end of the day that’s a bandaid
> solution. I think I can get the import stuff to work reasonably well (a lot
> of the infrastructure to capture types is already present in the current
> generatefortranstubs).
If you can get this to work, we should definitely do it. Was there a
question about getting it to work?
     Matt
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: (312) 694-3391
> On Mar 16, 2021, at 12:56, Barry Smith <bsmith at petsc.dev> wrote:
>    Jacob,
>      I split  the mat definitions in the MR
> https://gitlab.com/petsc/petsc/-/merge_requests/3696 and this reduced
> memory requirements enough to get builds through on some VM that failed
> previously ran out of memory (with gfortran).
>      The petsc*mod.F90 files are all handwritten so it is ok to manually
> change them with imports if that helps the IBM compiler. To me the best
> solution is to first split the files when possible (it is often not or just
>      Note also the MR
> https://gitlab.com/petsc/petsc/-/merge_requests/3715/diffs which may help
> a great deal with the IBM compiler or not.
>      Thanks
>      Barry
> On Mar 16, 2021, at 11:47 AM, Jacob Faibussowitsch <jacob.fai at gmail.com>
> wrote:
> Ok something I have gotten to work, but only doing things by hand in
> petscvecmod.F90:
> diff --git a/src/vec/f90-mod/petscvecmod.F90
> b/src/vec/f90-mod/petscvecmod.F90
> index 0c447156b9..ef3e2e2e55 100644
> --- a/src/vec/f90-mod/petscvecmod.F90
> +++ b/src/vec/f90-mod/petscvecmod.F90
>  module petscisdef
>  use petscisdefdummy
>  interface operator(.ne.)
>  function isnotequal(A,B)
> -  use petscisdefdummy
> + import tIS
>    logical isnotequal
>    type(tIS), intent(in) :: A,B
>  end function isnotequal
> This works for everything wrapped in a module which contains an interface
> block. For dangling functions the following works:
> + use petscisdef, only: tIs
>    logical isnotequal
>    isnotequal = (A%v .ne. B%v)
> Do our fortran stub generators have any notion of types? Specifically
> types that originate from petsc?
> Best regards,
> On Mar 16, 2021, at 11:11, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 16 Mar 2021, Jacob Faibussowitsch wrote:
> My [partial] change is in branch balay/reorg-f90-for-xlf
> Satish is this branch pushed? I’d like to send it to the ibm folks to see
> if it works for them as well.
> Sorry - pushed now. From what I remember - it didn't work.
> Satish
> They also added this extra follow up:
> The change we did in the source files is to replace all the "use pet*"
> statements in all the Interface blocks with IMPORT statement.
> The nature of this workaround is to reduce the number of symbols that the
> compiler have to create, which exceeded the limitation and caused ICE.
> Every USE statement in an interface block opens up the module symbol file
> and reads all the symbols from it and creates an entity for each symbol in
> compiler. This is unnecessary when the module already has the same USE
> statement in the module scope. Instead, users can use IMPORT statement to
> make the module symbols accessible inside interface face blocks.
> With the change, the compiler would only read the module symbol file once
> and create one set of symbols where the old code reads the module symbol
> files as many times as the number of the USE statements in Interface blocks
> and create that many sets of duplicate symbols. Replacing those USE
> statements with IMPORT statements also shortens the compile time
> significantly.
> Best regards,
> On Mar 3, 2021, at 13:43, Satish Balay via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
> The only change I can get working (i.e avoid compile errors) is to split
> petscvecmod.F90 into 2 source files - but I don't know if this will help
> with xlf..
> Satish
> Sure - once any change works locally [for gcc and xlf]
> When I try - I get a bunch of errors.. [yet to digest them.]
> Can you please give the following source code workaround a try?
> Since there is already "use petscvecdefdummy" at the module scope, one
> workaround might be to remove the unnecessary "use petscvecdefdummy" in
> vecnotequal and vecequals
> and all similar procedures.
> For example, the test case has:
>      module petscvecdef
>      function vecnotequal(A,B)
>        logical vecnotequal
>        type(tVec), intent(in) :: A,B
>        vecnotequal = (A%v .ne. B%v)
>      end function
> Ok - try this suggestion:
> index 0c447156b9..81968c7ca1 100644
> @@ -77,7 +77,6 @@
> -            use petscvecdefdummy
>            logical vecnotequal
>          end function
>         FC arch-linux-c-debug/obj/vec/f90-mod/petscvecmod.o
> /home/balay/petsc/src/vec/f90-mod/petscvecmod.F90:81:22:
>  81 |             type(tVec), intent(in) :: A,B
>     |                      1
> Error: Derived type ‘tvec’ at (1) is being used before it is defined
> /home/balay/petsc/include/../src/vec/f90-mod/ftn-auto-interfaces/petscis.h90:2:10:
>   2 |       use petscvecdef
>     |          1
> Fatal Error: Cannot open module file ‘petscvecdef.mod’ for reading at (1):
> No such file or directory
> Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210316/399c43db/attachment-0001.html>
