[petsc-dev] integrate petsc4py tarball generation with petsc tarball generation
Satish Balay
balay at mcs.anl.gov
Mon Mar 15 11:08:15 CDT 2021
Ok - I can look at updating builddist script to build PETSc and
PETSc4py [with python2 - and prerequistes installed] before attempting
to build python docs [and petsc4py tarball]
Satish
On Mon, 15 Mar 2021, Barry Smith wrote:
> Satish,
> I think some of the python documentation tools used, epydoc, require that the python package it is documenting exists and is run-able since it probably uses the self-documenting features of Python. This makes perfect sense for Python. A python package cannot provide help messages unless you can import it.
> Barry
> Maybe it could be rigged that petsc4py would allow itself to be imported and produce help messages without loading the PETSc libraries, this would require digging around a bit in how petsc4py loads the PETSc dynamic library.
> > On Mar 15, 2021, at 10:42 AM, Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> > On Mon, 15 Mar 2021, Satish Balay wrote:
> >>> and run "make sdist".
> >> Ah - ok. Will check this to see if I can generate the tarball in sync
> >> with petsc tarball. What source files need updating for
> >> release/version info?
> > Is it required to build PETSc library - to build petsc4py tarball?
> > Satish
> > balay at sb /home/balay/tmp/petsc/src/binding/petsc4py (main=)
> > $ make sdist
> > python setup.py build_src
> > running build_src
> > cythonizing 'petsc4py.PETSc.pyx' -> 'petsc4py.PETSc.c'
> > cythonizing 'libpetsc4py/libpetsc4py.pyx' -> 'libpetsc4py/libpetsc4py.c'
> > /usr/bin/rst2html --input-encoding=utf-8 --no-compact-lists --cloak-email-addresses ./LICENSE.rst > docs/LICENSE.html
> > /usr/bin/rst2html --input-encoding=utf-8 --no-compact-lists --cloak-email-addresses ./CHANGES.rst > docs/CHANGES.html
> > /usr/bin/rst2html --input-encoding=utf-8 --no-compact-lists --cloak-email-addresses docs/index.rst > docs/index.html
> > mkdir -p build/doctrees docs/usrman
> > sphinx-build -b html -d build/doctrees \
> > docs/source docs/usrman
> > Running Sphinx v3.2.1
> > building [mo]: targets for 0 po files that are out of date
> > building [html]: targets for 6 source files that are out of date
> > updating environment: [new config] 6 added, 0 changed, 0 removed
> > reading sources... [100%] tutorial
> > looking for now-outdated files... none found
> > pickling environment... done
> > checking consistency... /home/balay/tmp/petsc/src/binding/petsc4py/docs/source/manual.rst: WARNING: document isn't included in any toctree
> > done
> > preparing documents... done
> > writing output... [100%] tutorial
> > generating indices... genindexdone
> > writing additional pages... searchdone
> > copying static files... ... done
> > copying extra files... done
> > dumping search index in English (code: en)... done
> > dumping object inventory... done
> > build succeeded, 1 warning.
> > The HTML pages are in docs/usrman.
> > rm -f docs/usrman/.buildinfo
> > mkdir -p docs/apiref
> > env CFLAGS=-O0 python2 setup.py -q build --build-lib build/lib.py2
> > /usr/bin/ld: cannot find -lpetsc
> > collect2: error: ld returned 1 exit status
> > error: command 'gcc' failed with exit status 1
> > make: *** [makefile:110: epydoc-html] Error 1
