[petsc-dev] Commit squashing in MR
Scott Kruger
kruger at txcorp.com
Wed Mar 3 10:39:09 CST 2021
Attached is a little presentation that I gave to some fellow devs at
Tech-X. It's a rehash of what has been discussed here, but the
graphical nature might be useful.
Scott
On 2021-03-02 21:32, Jed Brown did write:
> Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> > On Wed, 3 Mar 2021, Blaise A Bourdin wrote:
> >> Hi,
> >> This is not technically a petsc question.
> >> It would be great to have a short section in the PETSc integration workflow document explaining how to squash commits in a MR for git-impaired developers like me.
> >> Anybody wants to pitch in, or explain me how to do this?
> > To squash commits - I use the 'squash' action in 'git rebase -i HASH' and figure out the HASH to use from 'gitk main..branch'
> > [as git rebase requires the commit prior to the first commit of interest]
> > git provides many ways of modifying the branch (and the rebase topic is very generic) so I think its best to rely on proper git docs/tutorials
> > [and its not really specific to petsc workflow]
> You can do it in one line, without changing the base:
> git rebase -i $(git merge-base main HEAD)
> An alternative is
> git rebase -i main
> which gives you interactive rebase to replay on top of current 'main'. This does two things at once and changing the base for your branch is not always desirable.
Scott Kruger
Tech-X Corporation kruger at txcorp.com
5621 Arapahoe Ave, Suite A Phone: (720) 466-3196
Boulder, CO 80303 Fax: (303) 448-7756
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210303/df9d38cc/attachment-0001.obj>
