[petsc-dev] VecGetArrayAndMemType
    Matthew Knepley
    knepley at gmail.com
    Thu Jun 24 14:05:42 CDT 2021
On Thu, Jun 24, 2021 at 9:58 AM Mark Adams <mfadams at lbl.gov> wrote:
> OK, I tried again and deleted the arch directory every time:
Okay, this changes the interface for OutputSequenceNumber. It _should_ be
backwards compatible. The likely error I would think
is that it thinks you have a timestep at first but not later, however that
should be an HDF5 error. Maybe it think the timestep is always
the same and overwrites?
     Matt
> (base) 09:56 (84933e400a...)|BISECTING ~/Codes/petsc2$ git bisect good
> d7dd068b66a8daa3a37c9e1556b34bd8def54922 is the first bad commit
> commit d7dd068b66a8daa3a37c9e1556b34bd8def54922
> Author: Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
> Date:   Wed Apr 14 21:22:37 2021 +0200
>     HDF5: Improve timestepping.
>     * add PetscViewerHDF5{Push,Pop,Is}Timestepping to control timestepping
> mode
>     * write timestepping attribute for datasets and check it on reading
>     * fail gracefully if trying to read non-timestepped dataset in
> timestepping mode and vice-versa (fix #425)
>     * rewrite src/vec/vec/tutorials/ex19.c to improve coverage for
> timestepping testing
>  doc/documentation/changes/dev.rst         |  19 ++-
>  include/petsc/private/viewerhdf5impl.h    |   2 +
>  include/petscviewerhdf5.h                 |   4 +
>  src/dm/impls/da/gr2.c                     |  21 ++--
>  src/dm/impls/plex/plexhdf5.c              |  25 +++-
>  src/sys/classes/viewer/impls/hdf5/hdf5v.c | 124 ++++++++++++++++++--
>  src/vec/is/is/impls/general/general.c     |  10 +-
>  src/vec/is/utils/hdf5io.c                 |  45 +++++---
>  src/vec/vec/impls/mpi/pdvec.c             |  14 ++-
>  src/vec/vec/tutorials/ex19.c              | 186
>  src/vec/vec/tutorials/output/ex19_2.out   |   0
>  src/vec/vec/tutorials/output/ex19_3.out   |   0
>  src/vec/vec/tutorials/output/ex19_4.out   |   0
>  13 files changed, 320 insertions(+), 130 deletions(-)
>  delete mode 100644 src/vec/vec/tutorials/output/ex19_2.out
>  delete mode 100644 src/vec/vec/tutorials/output/ex19_3.out
>  delete mode 100644 src/vec/vec/tutorials/output/ex19_4.out
> On Thu, Jun 24, 2021 at 7:04 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jun 24, 2021 at 7:00 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> OK, this is what I get with bisect:
>>> (base) 06:54 (c3b2925bfb...)|BISECTING ~/Codes/petsc2$ git bisect good
>>> The merge base c3b2925bfbe1c0a0b3a69c9a76295d0747e33d47 is bad.
>>> This means the bug has been fixed between
>>> c3b2925bfbe1c0a0b3a69c9a76295d0747e33d47 and
>>> [09da24df01e50defd94bc4f7396f866a808ecea5
>>> c3b2925bfbe1c0a0b3a69c9a76295d0747e33d47].
>>> (base) 06:56 (v3.15.1) ~/Codes/petsc2$ git checkout
>>> Previous HEAD position was 09da24df01 Increase patchlevel to 3.15.1
>>> HEAD is now at c3b2925bfb Merge branch 'knepley-main-patch-78504' into
>>> 'release'
>>> (base) 06:56 (c3b2925bfb...) ~/Codes/petsc2$
>> I do not understand. Neither of those commits do anything.
>>    Matt
>>> On Wed, Jun 23, 2021 at 11:14 PM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> Mark,
>>>>   I am not sure what your problem is.  If it is a regression, can you
>>>> bisect it?
>>>> --Junchao Zhang
>>>> On Wed, Jun 23, 2021 at 4:04 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> I also tried commenting out the second VecView, so there is just one
>>>>> step in the file, and the .h5 file is only 8 bytes smaller and the .xmf
>>>>> file goes from 5373  bytes to 3090 bytes.
>>>>> On Wed, Jun 23, 2021 at 4:01 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> It is not a device issue but it is a regression.
>>>>>> Landau ex1 is tiny and just calls VecView before and after the
>>>>>> TSsolve, which is one time step. If you add "*-dm_view hdf5:f.h5
>>>>>> -vec_view hdf5:f.h5::append -dm_landau_Ez 10.*" to landau/ex1 (see
>>>>>> below), you get an h5 file with two time steps, as it should be.
>>>>>> This is a huge electric field, Ez=10, which makes the electron
>>>>>> distribution (u_e) get visibly pulled off center.
>>>>>> In Visit, both time steps have identical data that is clearly after
>>>>>> the solve and not the initial condition (see attached).
>>>>>> I ran this again with -ex1_ts_max_steps 0 and get the expected
>>>>>> result of two steps/frames with the symmetric initial condition in both.
>>>>>> THis is correct behavior.
>>>>>> Any ideas?
>>>>>> Thanks
>>>>>> diff --git a/src/ts/utils/dmplexlandau/tutorials/ex1.c
>>>>>> b/src/ts/utils/dmplexlandau/tutorials/ex1.c
>>>>>> index 9e4c8f1b61..31dfda2fad 100644
>>>>>> --- a/src/ts/utils/dmplexlandau/tutorials/ex1.c
>>>>>> +++ b/src/ts/utils/dmplexlandau/tutorials/ex1.c
>>>>>> @@ -66,6 +66,6 @@ int main(int argc, char **argv)
>>>>>>    test:
>>>>>>      suffix: 0
>>>>>>      requires: p4est !complex
>>>>>> -    args: -petscspace_degree 3 -petscspace_poly_tensor 1
>>>>>> -dm_landau_type p4est -dm_landau_ion_masses 2,4 -dm_landau_ion_charges 1,18
>>>>>> -dm_landau_thermal_temps 5,5,.5 -dm_landau_n 1.00018,1,1e-5 -dm_landau_n_0
>>>>>> 1e20 -ex1_ts_monitor -ex1_snes_rtol 1.e-14 -ex1_snes_stol 1.e-14
>>>>>> -ex1_snes_monitor -ex1_snes_converged_reason -ex1_ts_type arkimex
>>>>>> -ex1_ts_arkimex_type 1bee -ex1_ts_max_snes_failures -1 -ex1_ts_rtol 1e-1
>>>>>> -ex1_ts_dt 1.e-1 -ex1_ts_max_time 1 -ex1_ts_adapt_clip .5,1.25
>>>>>> -ex1_ts_adapt_scale_solve_failed 0.75
>>>>>> -ex1_ts_adapt_time_step_increase_delay 5 -ex1_ts_max_steps 1 -ex1_pc_type
>>>>>> lu -ex1_ksp_type preonly -dm_landau_amr_levels_max 7
>>>>>> -dm_landau_domain_radius 5 -dm_landau_amr_re_levels 0 -dm_landau_re_radius
>>>>>> 1 -dm_landau_amr_z_refine1 1 -dm_landau_amr_z_refine2 0
>>>>>> -dm_landau_amr_post_refine 0 -dm_landau_z_radius1 .1 -dm_landau_z_radius2
>>>>>> .1 -dm_refine 1 -dm_landau_gpu_assembly false
>>>>>> +    args: -petscspace_degree 3 -petscspace_poly_tensor 1
>>>>>> .1 -dm_refine 1 -dm_landau_gpu_assembly false *-dm_view hdf5:f.h5
>>>>>>  TEST*/
>>>>>> On Wed, Jun 23, 2021 at 1:38 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> Landau ex1 should work. I will test.
>>>>>>> On Wed, Jun 23, 2021 at 10:47 AM Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Wed, Jun 23, 2021 at 10:44 AM Junchao Zhang <
>>>>>>>> junchao.zhang at gmail.com> wrote:
>>>>>>>>> Use VecGetArrayRead/Write() to get up-to-date host pointers to the
>>>>>>>>> vector array.
>>>>>>>> I think Mark is saying that those are not working. We do call
>>>>>>>> VecGetArrayRead() in the HDF5 code.
>>>>>>>> Mark, it seem like a small broken code is necessary.
>>>>>>>>   Thanks,
>>>>>>>>     Matt
>>>>>>>>> --Junchao Zhang
>>>>>>>>> On Wed, Jun 23, 2021 at 9:15 AM Mark Adams <mfadams at lbl.gov>
>>>>>>>>> wrote:
>>>>>>>>>> First, there seem to be two pages for VecGetArrayAndMemType (one
>>>>>>>>>> has a pointer to the other).
>>>>>>>>>> So I need to get a CPU array for HDF5 viewing. Totally broken for
>>>>>>>>>> devices.
>>>>>>>>>> I don't find a VecGetArrayCpu[HOST] that does the right thing.
>>>>>>>>>> Perhaps have VecGetArrayAndMemType return a valid CPU pointer
>>>>>>>>>> when "mtype==NULL"?
>>>>>>>>>> Mark
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210624/8266dbe9/attachment.html>
