[petsc-dev] VecGetArrayAndMemType
Jed Brown jed at jedbrown.org
Thu Jun 24 13:22:33 CDT 2021
https://gitlab.com/petsc/petsc/-/commit/d7dd068b66a8daa3a37c9e1556b34bd8def54922
On Thu, Jun 24, 2021, at 11:40 AM, Mark Adams wrote:
> How does one view a commit on gitlab?
> I would like to look at d7dd068b66a8daa3a37c9e1556b34bd8def54922
> On Thu, Jun 24, 2021 at 9:58 AM Mark Adams <mfadams at lbl.gov> wrote:
>> OK, I tried again and deleted the arch directory every time:
>> (base) 09:56 (84933e400a...)|BISECTING ~/Codes/petsc2$ git bisect good
>> d7dd068b66a8daa3a37c9e1556b34bd8def54922 is the first bad commit
>> commit d7dd068b66a8daa3a37c9e1556b34bd8def54922
>> Author: Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
>> Date:   Wed Apr 14 21:22:37 2021 +0200
>>     HDF5: Improve timestepping.
>>     * add PetscViewerHDF5{Push,Pop,Is}Timestepping to control timestepping mode
>>     * write timestepping attribute for datasets and check it on reading
>>     * fail gracefully if trying to read non-timestepped dataset in timestepping mode and vice-versa (fix #425)
>>     * rewrite src/vec/vec/tutorials/ex19.c to improve coverage for timestepping testing
>>  doc/documentation/changes/dev.rst         |  19 ++-
>>  include/petsc/private/viewerhdf5impl.h    |   2 +
>>  include/petscviewerhdf5.h                 |   4 +
>>  src/dm/impls/da/gr2.c                     |  21 ++--
>>  src/dm/impls/plex/plexhdf5.c              |  25 +++-
>>  src/sys/classes/viewer/impls/hdf5/hdf5v.c | 124 ++++++++++++++++++--
>>  src/vec/is/is/impls/general/general.c     |  10 +-
>>  src/vec/is/utils/hdf5io.c                 |  45 +++++---
>>  src/vec/vec/impls/mpi/pdvec.c             |  14 ++-
>>  src/vec/vec/tutorials/ex19.c              | 186 +++++++++++++++++-------------
>>  src/vec/vec/tutorials/output/ex19_2.out   |   0
>>  src/vec/vec/tutorials/output/ex19_3.out   |   0
>>  src/vec/vec/tutorials/output/ex19_4.out   |   0
>>  13 files changed, 320 insertions(+), 130 deletions(-)
>>  delete mode 100644 src/vec/vec/tutorials/output/ex19_2.out
>>  delete mode 100644 src/vec/vec/tutorials/output/ex19_3.out
>>  delete mode 100644 src/vec/vec/tutorials/output/ex19_4.out
>> On Thu, Jun 24, 2021 at 7:04 AM Matthew Knepley <knepley at gmail.com> wrote:
>>> On Thu, Jun 24, 2021 at 7:00 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>> OK, this is what I get with bisect:
>>>> (base) 06:54 (c3b2925bfb...)|BISECTING ~/Codes/petsc2$ git bisect good
>>>> The merge base c3b2925bfbe1c0a0b3a69c9a76295d0747e33d47 is bad.
>>>> This means the bug has been fixed between c3b2925bfbe1c0a0b3a69c9a76295d0747e33d47 and [09da24df01e50defd94bc4f7396f866a808ecea5 c3b2925bfbe1c0a0b3a69c9a76295d0747e33d47].
>>>> (base) 06:56 (v3.15.1) ~/Codes/petsc2$ git checkout c3b2925bfbe1c0a0b3a69c9a76295d0747e33d47
>>>> Previous HEAD position was 09da24df01 Increase patchlevel to 3.15.1
>>>> HEAD is now at c3b2925bfb Merge branch 'knepley-main-patch-78504' into 'release'
>>>> (base) 06:56 (c3b2925bfb...) ~/Codes/petsc2$
>>> I do not understand. Neither of those commits do anything.
>>>    Matt
>>>> On Wed, Jun 23, 2021 at 11:14 PM Junchao Zhang <junchao.zhang at gmail.com> wrote:
>>>>> Mark,
>>>>>   I am not sure what your problem is.  If it is a regression, can you bisect it?
>>>>> --Junchao Zhang
>>>>> On Wed, Jun 23, 2021 at 4:04 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> I also tried commenting out the second VecView, so there is just one step in the file, and the .h5 file is only 8 bytes smaller and the .xmf file goes from 5373  bytes to 3090 bytes.
>>>>>> On Wed, Jun 23, 2021 at 4:01 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> It is not a device issue but it is a regression.
>>>>>>> Landau ex1 is tiny and just calls VecView before and after the TSsolve, which is one time step. If you add "*-dm_view hdf5:f.h5 -vec_view hdf5:f.h5::append -dm_landau_Ez 10.*" to landau/ex1 (see below), you get an h5 file with two time steps, as it should be.
>>>>>>> This is a huge electric field, Ez=10, which makes the electron distribution (u_e) get visibly pulled off center.
>>>>>>> In Visit, both time steps have identical data that is clearly after the solve and not the initial condition (see attached).
>>>>>>> I ran this again with -ex1_ts_max_steps 0 and get the expected result of two steps/frames with the symmetric initial condition in both. THis is correct behavior.
>>>>>>> Any ideas?
>>>>>>> Thanks
>>>>>>> diff --git a/src/ts/utils/dmplexlandau/tutorials/ex1.c b/src/ts/utils/dmplexlandau/tutorials/ex1.c
>>>>>>> index 9e4c8f1b61..31dfda2fad 100644
>>>>>>> --- a/src/ts/utils/dmplexlandau/tutorials/ex1.c
>>>>>>> +++ b/src/ts/utils/dmplexlandau/tutorials/ex1.c
>>>>>>> @@ -66,6 +66,6 @@ int main(int argc, char **argv)
>>>>>>>    test:
>>>>>>>      suffix: 0
>>>>>>>      requires: p4est !complex
>>>>>>> -    args: -petscspace_degree 3 -petscspace_poly_tensor 1 -dm_landau_type p4est -dm_landau_ion_masses 2,4 -dm_landau_ion_charges 1,18 -dm_landau_thermal_temps 5,5,.5 -dm_landau_n 1.00018,1,1e-5 -dm_landau_n_0 1e20 -ex1_ts_monitor -ex1_snes_rtol 1.e-14 -ex1_snes_stol 1.e-14 -ex1_snes_monitor -ex1_snes_converged_reason -ex1_ts_type arkimex -ex1_ts_arkimex_type 1bee -ex1_ts_max_snes_failures -1 -ex1_ts_rtol 1e-1 -ex1_ts_dt 1.e-1 -ex1_ts_max_time 1 -ex1_ts_adapt_clip .5,1.25 -ex1_ts_adapt_scale_solve_failed 0.75 -ex1_ts_adapt_time_step_increase_delay 5 -ex1_ts_max_steps 1 -ex1_pc_type lu -ex1_ksp_type preonly -dm_landau_amr_levels_max 7 -dm_landau_domain_radius 5 -dm_landau_amr_re_levels 0 -dm_landau_re_radius 1 -dm_landau_amr_z_refine1 1 -dm_landau_amr_z_refine2 0 -dm_landau_amr_post_refine 0 -dm_landau_z_radius1 .1 -dm_landau_z_radius2 .1 -dm_refine 1 -dm_landau_gpu_assembly false
>>>>>>> +    args: -petscspace_degree 3 -petscspace_poly_tensor 1 -dm_landau_type p4est -dm_landau_ion_masses 2,4 -dm_landau_ion_charges 1,18 -dm_landau_thermal_temps 5,5,.5 -dm_landau_n 1.00018,1,1e-5 -dm_landau_n_0 1e20 -ex1_ts_monitor -ex1_snes_rtol 1.e-14 -ex1_snes_stol 1.e-14 -ex1_snes_monitor -ex1_snes_converged_reason -ex1_ts_type arkimex -ex1_ts_arkimex_type 1bee -ex1_ts_max_snes_failures -1 -ex1_ts_rtol 1e-1 -ex1_ts_dt 1.e-1 -ex1_ts_max_time 1 -ex1_ts_adapt_clip .5,1.25 -ex1_ts_adapt_scale_solve_failed 0.75 -ex1_ts_adapt_time_step_increase_delay 5 -ex1_ts_max_steps 1 -ex1_pc_type lu -ex1_ksp_type preonly -dm_landau_amr_levels_max 7 -dm_landau_domain_radius 5 -dm_landau_amr_re_levels 0 -dm_landau_re_radius 1 -dm_landau_amr_z_refine1 1 -dm_landau_amr_z_refine2 0 -dm_landau_amr_post_refine 0 -dm_landau_z_radius1 .1 -dm_landau_z_radius2 .1 -dm_refine 1 -dm_landau_gpu_assembly false *-dm_view hdf5:f.h5 -vec_view hdf5:f.h5::append -dm_landau_Ez 10.*
>>>>>>>  TEST*/
>>>>>>> On Wed, Jun 23, 2021 at 1:38 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> Landau ex1 should work. I will test.
>>>>>>>> On Wed, Jun 23, 2021 at 10:47 AM Matthew Knepley <knepley at gmail.com> wrote:
>>>>>>>>> On Wed, Jun 23, 2021 at 10:44 AM Junchao Zhang <junchao.zhang at gmail.com> wrote:
>>>>>>>>>> Use VecGetArrayRead/Write() to get up-to-date host pointers to the vector array.
>>>>>>>>> I think Mark is saying that those are not working. We do call VecGetArrayRead() in the HDF5 code.
>>>>>>>>> Mark, it seem like a small broken code is necessary.
>>>>>>>>>   Thanks,
>>>>>>>>>     Matt
>>>>>>>>>> --Junchao Zhang
>>>>>>>>>> On Wed, Jun 23, 2021 at 9:15 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>>>>> First, there seem to be two pages for VecGetArrayAndMemType (one has a pointer to the other).
>>>>>>>>>>> So I need to get a CPU array for HDF5 viewing. Totally broken for devices.
>>>>>>>>>>> I don't find a VecGetArrayCpu[HOST] that does the right thing.
>>>>>>>>>>> Perhaps have VecGetArrayAndMemType return a valid CPU pointer when "mtype==NULL"?
>>>>>>>>>>> Mark
>>>>>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210624/97b6b4a4/attachment-0001.html>
