[petsc-dev] Petsc Parallel Matrix Vector Multiplication for Skew-Symmetric Matrix
Matthew Knepley
knepley at gmail.com
Wed Jun 2 14:26:33 CDT 2021
On Wed, Jun 2, 2021 at 3:23 PM Yağmur Aksan <yagmuraksan at gmail.com> wrote:
> Hello,
> I need a function that parallelly multiplies skew-symmetric matrix and
> vector. Is there any function that Petsc provides?
> To do so, I think of using matMult function in Petsc and changing it to
> work with skew-symmetric matrices. But, I haven't found the implementation
> of MatMult function. If there isn't any other better option that you can
> recommend me, could you please tell me the link for the implementation of
> MatMult function?
Do you want to save memory by using the special format? It will not save
computing, and the speed improvement can be very small.
Matt
> Thank you.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210602/81bd57f4/attachment.html>
