[petsc-dev] obscure changes in TSGetStages_Theta
Zhang, Hong
hongzhang at anl.gov
Sat Jan 23 12:04:59 CST 2021
Done. Please check https://gitlab.com/petsc/petsc/-/merge_requests/3583
Sorry for any disturbance it caused. It was for the convenience of the adjoint implementation. The stages returned by TSGetStages_Theta currently do not reflect the true stages associated with these methods. The endpoint variant actually has two stages. This will be changed in a separate forthcoming MR, where TSRestoreStages() will be added and TSGetStages will return an array of vectors for the endpoint variant.
Hong
On Jan 21, 2021, at 4:16 AM, Stefano Zampini <stefano.zampini at gmail.com<mailto:stefano.zampini at gmail.com>> wrote:
Hong,
I do not understand why you changed the behavior of TSGetStages_Theta https://gitlab.com/petsc/petsc/-/merge_requests/3500/diffs#a582bbaec75f4ae14bbf97d1d0404073ca89ff09_1194_1209 with this MR https://gitlab.com/petsc/petsc/-/merge_requests/3500
Now, the non-endpoint variant does no longer use th->X as stage!
Please revert this change
Thanks
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210123/2b8d5ac0/attachment.html>
