[petsc-dev] bin/sh error while running tests
Jed Brown
jed at jedbrown.org
Wed Jan 20 09:57:46 CST 2021
Yes, I'd rather either not call `report_tests.py` when we don't want to report anything or pass it a flag that says how quiet/verbose to be. If we pass the verbosity flag, it can still run consistency checks and decide whether to return nonzero, so that seems preferable.
We should probably use `/bin/dash` (because `/bin/sh` is often a symlink to bash) in the test suite to avoid these issues cropping up again.
Scott Kruger <kruger at txcorp.com> writes:
> OK. To fix Stefano's other complaint, I see now that it is best to move
> the logic to report_tests.py with a new flag. This will fix all
> bashism's as well as fix Jed's complaint of the weird programming of
> having a null dependency.
> Scott
> On 1/20/21 7:40 AM, Satish Balay via petsc-dev wrote:
>> Probably best to stick with 'sh' - if bash were universal - we could add in this dependency..
>> diff --git a/config/BuildSystem/config/programs.py b/config/BuildSystem/config/programs.py
>> index f35baa2e0c..6a684310dd 100755
>> --- a/config/BuildSystem/config/programs.py
>> +++ b/config/BuildSystem/config/programs.py
>> @@ -70,7 +70,7 @@ class Configure(config.base.Configure):
>> def configurePrograms(self):
>> '''Check for the programs needed to build and run PETSc'''
>> - self.getExecutable('sh', getFullPath = 1, resultName = 'SHELL')
>> + self.getExecutable('bash', getFullPath = 1, resultName = 'SHELL')
>> if not hasattr(self, 'SHELL'): raise RuntimeError('Could not locate sh executable')
>> self.getExecutable('sed', getFullPath = 1)
>> if not hasattr(self, 'sed'): raise RuntimeError('Could not locate sed executable')
>> Satish
>> On Wed, 20 Jan 2021, Stefano Zampini wrote:
>>> as long as this gets fixed, I'm fine with any solution
>>> Il giorno mer 20 gen 2021 alle ore 16:04 Pierre Jolivet <pierre at joliv.et>
>>> ha scritto:
>>>> Sorry for the noise, I'm now just realizing that it is in fact exactly the
>>>> same bash-ism… (I prefer my “fix” though, but I guess the rest of Stefano’s
>>>> comment still holds true).
>>>> Thanks,
>>>> Pierre
>>>> On 20 Jan 2021, at 1:59 PM, Pierre Jolivet <pierre at joliv.et> wrote:
>>>> On 20 Jan 2021, at 12:11 PM, Stefano Zampini <stefano.zampini at gmail.com>
>>>> wrote:
>>>> This is an issue with the default shell used by the makefile. Below is my
>>>> fix. We should probably have a CI machine that checks for these
>>>> shell-related errors.
>>>> I second this. Just spent too much time finding this other bash-ism in
>>>> gmakefile.test…
>>>> https://gitlab.com/petsc/petsc/-/commit/e4b11943e93779206a0e5f2091646de2e86b10e3#551c4017403b9179c385d5600f43348b6288a751
>>>> 2021-01-20T11:21:22.5942304Z /usr/bin/sh: 1: test: false: unexpected operator
>>>> 2021-01-20T11:21:22.5981176Z make: *** [gmakefile.test:270: check-test-errors] Error 1
>>>> Thanks,
>>>> Pierre
>>>> diff --git a/gmakefile.test b/gmakefile.test
>>>> index c38e37f..ffd7bdb 100644
>>>> --- a/gmakefile.test
>>>> +++ b/gmakefile.test
>>>> @@ -379,10 +379,11 @@ starttime: pre-clean $(libpetscall)
>>>> @$(eval STARTTIME := $(shell date +%s))
>>>> report_tests: starttime $(TESTTARGETS)
>>>> +ifeq ($(showreport),true)
>>>> @$(eval ENDTIME := $(shell date +%s))
>>>> - - at if test ${showreport} == "true"; then
>>>> elapsed_time=$$(($(ENDTIME)- $(STARTTIME))) && \
>>>> - $(PYTHON) $(CONFIGDIR)/report_tests.py -m $(MAKE) -d
>>>> $(TESTDIR)/counts -t 5 -e $${elapsed_time};\
>>>> - fi
>>>> + elapsed_time=$$(($(ENDTIME)- $(STARTTIME))) && \
>>>> + $(PYTHON) $(CONFIGDIR)/report_tests.py -m $(MAKE) -d
>>>> +endif
>>>> Il giorno mar 19 gen 2021 alle ore 20:41 Scott Kruger <kruger at txcorp.com>
>>>> ha scritto:
>>>>> I can't reproduce this with the latest master:
>>>>> hip 1261: git pull
>>>>> Already up to date.
>>>>> hip 1262: make -f gmakefile.test test search='notatest'
>>>>> Using MAKEFLAGS: -- search=notatest
>>>>> hip 1263:
>>>>> On 1/19/21 8:19 AM, Stefano Zampini wrote:
>>>>> Just rebased over latest master and got this
>>>>> zampins at vulture:~/Devel/petsc$ make -f gmakefile.test test
>>>>> search='notatest'
>>>>> Stefano
>>>>> Tech-X Corporation kruger at txcorp.com
>>>>> 5621 Arapahoe Ave, Suite A Phone: (720) 466-3196
>>>>> Boulder, CO 80303 Fax: (303) 448-7756
>>>> Stefano
