[petsc-dev] bin/sh error while running tests
    Scott Kruger
    kruger at txcorp.com
    Wed Jan 20 09:51:38 CST 2021
OK.  To fix Stefano's other complaint, I see now that it is best to move
the logic to report_tests.py with a new flag.  This will fix all
bashism's as well as fix Jed's complaint of the weird programming of
having a null dependency.
Scott
On 1/20/21 7:40 AM, Satish Balay via petsc-dev wrote:
> Probably best to stick with 'sh' - if bash were universal - we could add in this dependency..
> diff --git a/config/BuildSystem/config/programs.py b/config/BuildSystem/config/programs.py
> index f35baa2e0c..6a684310dd 100755
> --- a/config/BuildSystem/config/programs.py
> +++ b/config/BuildSystem/config/programs.py
> @@ -70,7 +70,7 @@ class Configure(config.base.Configure):
>     def configurePrograms(self):
>       '''Check for the programs needed to build and run PETSc'''
> -    self.getExecutable('sh',   getFullPath = 1, resultName = 'SHELL')
> +    self.getExecutable('bash',   getFullPath = 1, resultName = 'SHELL')
>       if not hasattr(self, 'SHELL'): raise RuntimeError('Could not locate sh executable')
>       self.getExecutable('sed',  getFullPath = 1)
>       if not hasattr(self, 'sed'): raise RuntimeError('Could not locate sed executable')
> Satish
> On Wed, 20 Jan 2021, Stefano Zampini wrote:
>> as long as this gets fixed, I'm fine with any solution
>> Il giorno mer 20 gen 2021 alle ore 16:04 Pierre Jolivet <pierre at joliv.et>
>> ha scritto:
>>> Sorry for the noise, I'm now just realizing that it is in fact exactly the
>>> same bash-ism… (I prefer my “fix” though, but I guess the rest of Stefano’s
>>> comment still holds true).
>>> Thanks,
>>> Pierre
>>> On 20 Jan 2021, at 1:59 PM, Pierre Jolivet <pierre at joliv.et> wrote:
>>> On 20 Jan 2021, at 12:11 PM, Stefano Zampini <stefano.zampini at gmail.com>
>>> wrote:
>>> This is an issue with the default shell used by the makefile. Below is my
>>> fix. We should probably have a CI machine that checks for these
>>> shell-related errors.
>>> I second this. Just spent too much time finding this other bash-ism in
>>> gmakefile.test…
>>> https://gitlab.com/petsc/petsc/-/commit/e4b11943e93779206a0e5f2091646de2e86b10e3#551c4017403b9179c385d5600f43348b6288a751
>>> 2021-01-20T11:21:22.5942304Z /usr/bin/sh: 1: test: false: unexpected operator
>>> 2021-01-20T11:21:22.5981176Z make: *** [gmakefile.test:270: check-test-errors] Error 1
>>> Thanks,
>>> Pierre
>>> diff --git a/gmakefile.test b/gmakefile.test
>>> index c38e37f..ffd7bdb 100644
>>> --- a/gmakefile.test
>>> +++ b/gmakefile.test
>>> @@ -379,10 +379,11 @@ starttime: pre-clean $(libpetscall)
>>>          @$(eval STARTTIME := $(shell date +%s))
>>>   report_tests: starttime $(TESTTARGETS)
>>> +ifeq ($(showreport),true)
>>>          @$(eval ENDTIME := $(shell date +%s))
>>> -       - at if test ${showreport} == "true"; then
>>>   elapsed_time=$$(($(ENDTIME)- $(STARTTIME))) && \
>>> -       $(PYTHON) $(CONFIGDIR)/report_tests.py -m $(MAKE) -d
>>> $(TESTDIR)/counts -t 5 -e $${elapsed_time};\
>>> -    fi
>>> +       elapsed_time=$$(($(ENDTIME)- $(STARTTIME))) && \
>>> +       $(PYTHON) $(CONFIGDIR)/report_tests.py -m $(MAKE) -d
>>> +endif
>>> Il giorno mar 19 gen 2021 alle ore 20:41 Scott Kruger <kruger at txcorp.com>
>>> ha scritto:
>>>> I can't reproduce this with the latest master:
>>>> hip 1261: git pull
>>>> Already up to date.
>>>> hip 1262: make -f gmakefile.test test search='notatest'
>>>> Using MAKEFLAGS: -- search=notatest
>>>> hip 1263:
>>>> On 1/19/21 8:19 AM, Stefano Zampini wrote:
>>>> Just rebased over latest master and got this
>>>> zampins at vulture:~/Devel/petsc$ make -f gmakefile.test test
>>>> search='notatest'
>>>> Stefano
>>>> Tech-X Corporation               kruger at txcorp.com
>>>> 5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
>>>> Boulder, CO 80303                Fax:   (303) 448-7756
>>> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210120/21bb2358/attachment-0001.html>
