[petsc-dev] model for parallel ASM
Jacob Faibussowitsch jacob.fai at gmail.com
Mon Jan 11 10:37:06 CST 2021
> I could try this with fieldsplit/additive and Jacob's Vector object on Cuda, with Jacobi now of its ready. Jacob?
Still under construction, although depending on the exact vec ops you require you may be able to tinker something together. Note so far only direct vec compute ops have been given the stream treatment, for scatter/gather I think Junchao covers that in his NVSHMEM MR.
If you are just pipelining vectors ops into one another without any intermittent modification of scalars though then you are good to go. As of writing this I haven’t gotten round to  implementing device-side scalar modifications. So in a nutshell:
VecDotAsync(…, &r00, stream);
VecScaleAsync(…, r00, stream);
Is fully pipelined as long as you directly feed output to input, but
VecScaleAsync(…, 1./r00, stream);    <————— note modification of result
Is not.
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> On Jan 11, 2021, at 08:14, Mark Adams <mfadams at lbl.gov> wrote:
> Ah, so first first maybe the Solver does not need a stream because it uses VecScatter ?
> The model is 1) block to get your data, 2) doit non-blocking. If a vector is used in a non-GPU method that does not know about (1) you are hosed, but that is a detail.
> I like the middle, single loop algo or whatever is easier, keep it simple, and once it's running it is easy to an experiment with more loops.
> On Sun, Jan 10, 2021 at 9:38 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>> On Jan 10, 2021, at 1:30 PM, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>> On Sat, Jan 9, 2021 at 11:14 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>   Ok, fieldsplit, pretty much the same as what I said for block Jacobi.
>> static PetscErrorCode PCApply_FieldSplit(PC pc,Vec x,Vec y)
>>   PC_FieldSplit      *jac = (PC_FieldSplit*)pc->data;
>>   PetscErrorCode     ierr;
>>   PC_FieldSplitLink  ilink = jac->head;
>>   PetscInt           cnt,bs;
>>   PetscFunctionBegin;
>>   if (jac->type == PC_COMPOSITE_ADDITIVE) {
>>     if (jac->defaultsplit) {
>>       ierr = VecGetBlockSize(x,&bs);CHKERRQ(ierr);
>>       if (jac->bs > 0 && bs != jac->bs) SETERRQ2(PetscObjectComm((PetscObject)pc),PETSC_ERR_ARG_WRONGSTATE,"Blocksize of x vector %D does not match fieldsplit blocksize %D",bs,jac->bs);
>>       ierr = VecGetBlockSize(y,&bs);CHKERRQ(ierr);
>>       if (jac->bs > 0 && bs != jac->bs) SETERRQ2(PetscObjectComm((PetscObject)pc),PETSC_ERR_ARG_WRONGSTATE,"Blocksize of y vector %D does not match fieldsplit blocksize %D",bs,jac->bs);
>>       ierr = VecStrideGatherAll(x,jac->x,INSERT_VALUES);CHKERRQ(ierr);
>>       while (ilink) {
>>         ierr = PetscLogEventBegin(ilink->event,ilink->ksp,ilink->x,ilink->y,NULL);CHKERRQ(ierr);
>>         ierr = KSPSolve(ilink->ksp,ilink->x,ilink->y);CHKERRQ(ierr);
>> you need these KSPSolve() to not block which if you are using SuperLU_DIST means each call to
>>  PetscStackCall("SuperLU_DIST:PStatInit",PStatInit(&stat));        /* Initialize the statistics variables. */
>> #if defined(PETSC_USE_COMPLEX)
>>   PetscStackCall("SuperLU_DIST:pzgssvx",pzgssvx(&lu->options,&lu->A_sup,&lu->ScalePermstruct,(doublecomplex*)bptr,m,1,&lu->grid,&lu->LUstruct,&lu->SOLVEstruct,berr,&stat,&info));
>> #else
>>   PetscStackCall("SuperLU_DIST:pdgssvx",pdgssvx(&lu->options,&lu->A_sup,&lu->ScalePermstruct,bptr,m,1,&lu->grid,&lu->LUstruct,&lu->SOLVEstruct,berr,&stat,&info));
>> #endif
>> must be on a different stream and cannot block. Which means essentially the PStatInit and pdgssvx have to run completely on the GPU or have some complex CPU babysitting that allows them to be interlaced on the GPU while doing their CPU stuff.
>> It is not clear why the library code would be that complex but I don't understand streams well. SuperLU currently uses Thrust driven by CPU code, but is developing a pure GPU version. I can wait for the pure GPU version.
>> I doubt either thing is true and you are best off using the cuSparse Solvers which do run completely on the GPU in any stream you give them.
>> CUSparse does not have an LU factorization.
>> The factorization is even more of a nightmare, I think Sherry uses the GPU just to do blocks for her sequential factorization so I doubt very much it can handle multiple simultaneous factorizations.
>> Oh you were talking about the solves. (I have only been thinking about factorizations and that has caused some confusion I now see).
>> I am still not clear about the parallel dispatch. If an MPI serial library method needs a lot of complex logic to work perhaps look at other models? The XGC code uses OMP a lot and they dispatch asynchronous "solves" in an OMP loop. I'm not sure if being in an OMP thread buys you anything for a GPU solver but this is what they have done for CPU solvers. At one point they used PETSc for a LU solve and we (Barry) made some fixes to make it thread safe enough for this operation, but don't know what GPU "solvers" they have now running in this model on the GPU.
>> Regardless, my best guess as the basic model is something like:
>   The thing is streams manage their own dependencies so you don't want or need any CPU waits on them.  Assume both VecScatter and Solve take a stream and are not blocking. The code for CUDA GPUs could be
>  for all blocks i
>       VecScatter(i, i.stream)    // launches scatter kernel(s)
>  for all blocks i
>       Solve(i, i.stream)            // launches solve kernel(s)
>  for all blocks i
> launch here means the CPU gives the stream and the code and data pointers to the GPU to put in its queue and schedule when it can.
>   Since everything is non-blocking on the CPU just zips through the loops, taking about 10 micro-seconds for each "launch"  and the GPU manages the scheduling. You could also do
>   for all blocks i
>       VecScatter(i, i.stream)     // launches scatter kerkel(s)
>   Again the CPU just zips through all the loops giving the GPU a big list of kernels and the GPU manages the scheduling. The second approach would, I am guessing, be slightly slower since the GPU gets the scatter kernels with some time spacing between them (because the CPU is putting the later operations in the queue) so cannot schedule them as rapidly.
> There is also
>  for all blocks i
>  for all blocks i
> which may be as good as the first assuming the scatters take long enough to cover the time for all the other kernels to be launched by the CPU and queued up by the GPU.
>> For all blocks i,
>>    create a stream i.s, and launch a non-blocking vecScater with i.s
>> For all blocks i,
>>   vecScaterEnd(i),
>>   Solve(i.s, ....)  // So library solvers and our built-in solvers would need to take a stream or I guess that would get passed in through Jacob's vector class and the library interface code would need to take the Cuda stream out and give it to SuperLU, say.
>> For all blocks i,
>>   Wait (i.s)
>>   vecscatterBegin (i.s, ...)
>> For all blocks i,
>>  vecscatterEnd (i.s, ...)  // non-overlapping blocks so problem with adding values
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210111/6e24a4b7/attachment-0001.html>
