[petsc-dev] model for parallel ASM
    Mark Adams
    mfadams at lbl.gov
    Sun Jan 10 13:30:28 CST 2021
On Sun, Jan 10, 2021 at 2:28 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
wrote:
> I would like as much as possible to pass the cuda and hip streams to
> Kokkos, since I can directly handle much of the annoyance with wrangling
> multiple streams and stream objects externally. Last I checked on this
> Kokkos was moving towards allowing association of streams to functions, but
> admittedly this was a while back.
OK, good. I want to ask them about LU factorizations also. I will ask about
this.
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: (312) 694-3391
> On Jan 10, 2021, at 13:10, Mark Adams <mfadams at lbl.gov> wrote:
> On Sat, Jan 9, 2021 at 7:37 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
> wrote:
>> It is a single object that holds a pointer to every stream implementation
>> and toggleable type so it can be universally passed around. Currently has a
>> cudaStream and a hipStream but this is easily extendable to any other
>> stream implementation.
> Do you have any thoughts on how this would work with Kokkos?
> Would you want to feed Kokkos your Cuda/Hip, etc, stream or add a Kokkos
> backend to your object?
> Junchao might be the person to ask. I would guess Kokkos View (vector)
> objects carry a stream because they block on a "deep_copy", that moves data
> to/from the GPU, and it is blocking.
> Thanks,
> Mark
>> Best regards,
>> Cell: +1 (312) 694-3391
>> On Jan 9, 2021, at 18:19, Mark Adams <mfadams at lbl.gov> wrote:
>> Is this stream object going to have Cuda, Kokkos, etc., implementations?
>> On Sat, Jan 9, 2021 at 4:09 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
>> wrote:
>>> I’m currently working on an implementation of a general PetscStream
>>> object. Currently it only supports Vector ops and has a proof of concept
>>> KSPCG, but should be extensible to other objects when finished. Junchao is
>>> also indirectly working on pipeline support in his NVSHMEM MR. Take a look
>>> at either MR, it would be very useful to get your input, as tailoring
>>> either of these approaches for pipelined algorithms is key.
>>> Best regards,
>>> On Jan 9, 2021, at 15:01, Mark Adams <mfadams at lbl.gov> wrote:
>>> I would like to put a non-overlapping ASM solve on the GPU. It's not
>>> clear that we have a model for this.
>>> PCApply_ASM currently pipelines the scater with the subdomain solves. I
>>> think we would want to change this and do a 1) scatter begin loop, 2)
>>> scatter end and non-blocking solve loop, 3) solve-wait and scatter
>>> begging loop and 4) scatter end loop.
>>> I'm not sure how to go about doing this.
>>>  * Should we make a new PCApply_ASM_PARALLEL or dump this pipelining
>>> algorithm and rewrite PCApply_ASM?
>>>  * Add a solver-wait method to KSP?
>>> Thoughts?
>>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210110/b4c2d0eb/attachment-0001.html>
