[petsc-dev] Testing seems broken in master
Satish Balay
balay at mcs.anl.gov
Mon Jan 4 11:29:23 CST 2021
hm - indices are integers and its not ignored (i.e %d) - only the %f and %e diff is ignored (by default)
Satish
On Mon, 4 Jan 2021, Scott Kruger wrote:
> Is this just the 3rd problem?
> Regarding how you can end up with changes not being caught:
> The default (going all the way back to the old harness) is to not check
> numbers to avoid round-off errors giving false negatives (failures).
> Of course, sometimes you *want* to check the numbers; e.g., for indices. The
> solution for this is to add:
> diff_args: -j
> Scott
> On 12/31/20 4:40 PM, Barry Smith wrote:
> > I think I have it "fixed" now in the branch, once it passes the pipeline I
> > will shepard it through the MR quickly. Sorry about this, even all our CI
> > testing can miss a great deal.
> > Barry
> >> On Dec 31, 2020, at 2:44 PM, Barry Smith <bsmith at petsc.dev
> >> <mailto:bsmith at petsc.dev>> wrote:
> >> This is a different (3rd) problem. Funny it didn't bother anyone for two
> >> months.
> >> Fix is in barry/2020-12-29/fix-petscdiff-bracket but the pipeline keeps
> >> failing ts_tutorials_advection-diffusion-reaction-ex3_2 fails on different
> >> machines with slightly different counts. I don't see how this change could
> >> cause that! But gets old results on my machine. Very frustrating.
> >> Barry
> >>> On Dec 31, 2020, at 1:02 PM, Matthew Knepley <knepley at gmail.com
> >>> <mailto:knepley at gmail.com>> wrote:
> >>> On Thu, Dec 31, 2020 at 1:48 PM Barry Smith <bsmith at petsc.dev
> >>> So the programs output changes and should no longer match that
> >>> in the output/* file yet the test harness does not error with a
> >>> statement that the two outputs do not match?
> >>> I noticed the gmakegentest.py is not being run before it runs
> >>> the test? Does this mean it is just running all the old stuff
> >>> which does match fine?
> >>> Then either how petscdiff is called by the test harness has
> >>> changed or petscdiff has changed and does not detect changes
> >>> anymore
> >>> BTW: I always use -f ./gmakefile.test test not just the gmakefile
> >>> All the PETSc changes are trivial and can be seen with a
> >>> simple diff, it is hard to believe they would cause this
> >>> behavior but I guess they must.
> >>> You can go to PETSC_ARCH/tests/snes/tests and run the ex13
> >>> shell script directly.
> >>> It is the sed problem:
> >>> master *$:/PETSc3/petsc/petsc-dev$
> >>> /PETSc3/petsc/petsc-dev/lib/petsc/bin/petscdiff
> >>> /PETSc3/petsc/petsc-dev/src/snes/tests/output/ex13_bench.out
> >>> ex13_bench.tmp
> >>> sed: 1: "s/\033[1;31m//g": unbalanced brackets ([])
> >>> sed: 1: "s/\033[0;39m\033[0;49m//g": unbalanced brackets ([])
> >>> The error was getting eaten.
> >>> This is in current master. Is it fixed in a branch?
> >>> Matt
> >>> Barry
> >>>> On Dec 31, 2020, at 12:38 PM, Matthew Knepley
> >>>> <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> >>>> I just pulled master, and simple alterations to tests do not
> >>>> produce a failure:
> >>>> master *$:/PETSc3/petsc/petsc-dev$ PETSC_ARCH=arch-master-debug
> >>>> make -f ./gmakefile test search="snes_tests-ex13_bench"
> >>>> TIMEOUT=5000 EXTRA_OPTIONS="-dm_
> >>>> refine 0"
> >>>> Using MAKEFLAGS: EXTRA_OPTIONS=-dm_refine 0 TIMEOUT=5000
> >>>> search=snes_tests-ex13_bench
> >>>> TEST
> >>>> arch-master-debug/tests/counts/snes_tests-ex13_bench.counts
> >>>> ok snes_tests-ex13_bench
> >>>> ok diff-snes_tests-ex13_bench
> >>>> I check that the runs produce different output when done manually.
> >>>> Scott and Barry, could this be related to changed to testing?
> >>>> Thanks,
> >>>> Matt
> >>>> What most experimenters take for granted before they begin
> >>>> their experiments is infinitely more interesting than any
> >>>> results to which their experiments lead.
> >>>> -- Norbert Wiener
> >>>> https://www.cse.buffalo.edu/~knepley/
> >>>> <http://www.cse.buffalo.edu/%7Eknepley/>
> >>> What most experimenters take for granted before they begin their
> >>> experiments is infinitely more interesting than any results to which their
> >>> experiments lead.
> >>> -- Norbert Wiener
