[petsc-dev] Comparing binary output files in test harness
Blaise A Bourdin bourdin at lsu.edu
Thu Feb 18 22:59:01 CST 2021
I would like to write better tests for my exodus I/O functions and compare the binary files written to the drive instead of the output of the examples.
For instance, would it be possible to do the following:
	ex26 -i <input mesh> -o output1.exo; mpirun -np 2 ex26 -i <input mesh> -o output2.exo; exodiff output1.exo output2.exo
And check the result of exodiff, or run exodiff between output1.exo or output2.exo and a stored binary result?
Blaise
A.K. & Shirley Barton Professor of  Mathematics
Adjunct Professor of Mechanical Engineering
Adjunct of the Center for Computation & Technology
Louisiana State University, Lockett Hall Room 344, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 Web http://www.math.lsu.edu/~bourdin
