[petsc-dev] Fortran macOS Linkage Warning
Satish Balay
balay at mcs.anl.gov
Mon Feb 15 10:45:17 CST 2021
ok - gfortran is using:
> COLLECT_GCC_OPTIONS='-o' '/var/folders/9w/7dlszmmn6q1gd5yf3r9n79bc0000gn/T/petsc-dk9aiv7x/config.compilers/conftest' '-v' '-Wall' '-ffree-line-length-0' '-Wno-unused-dummy-argument' '-g' '-mmacosx-version-min=11.2.0' '-asm_macosx_version_min=11.2' '-shared-libgcc' '-mtune=core2'
Likely -mmacosx-version-min=11.2.0 option is causing this issue. I do not know why brew gfortran is using this option.
Satish
On Mon, 15 Feb 2021, Jacob Faibussowitsch wrote:
> I can reproduce the warning compiling just that simple code you listed. This is the compile command:
> mkdir -p build && gfortran -c -o ./build/conftest.o conftest.F90 && gcc -o ./build/libconftest.dylib ./build/conftest.o -dynamiclib -undefined dynamic_lookup && rm -rf ./build
> And error:
> ld: warning: object file (./build/conftest.o) was built for newer macOS version (11.2) than being linked (11.0)
> Note I recently uninstalled and reinstalled command line tools too, which does not seem to have fixed it.
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: (312) 694-3391
> > On Feb 15, 2021, at 11:30, Satish Balay <balay at mcs.anl.gov> wrote:
> > Here is the compile command and the warning:
> > ===== Checking linker
> > Executing: gfortran -c -o /var/folders/9w/7dlszmmn6q1gd5yf3r9n79bc0000gn/T/petsc-dk9aiv7x/config.setCompilers/conftest.o -I/var/folders/9w/7dlszmmn6q1gd5yf3r9n79bc0000gn/T/petsc-dk9aiv7x/config.setCompilers /var/folders/9w/7dlszmmn6q1gd5yf3r9n79bc0000gn/T/petsc-dk9aiv7x/config.setCompilers/conftest.F90
> > Successful compile:
> > Source:
> > function foo(a)
> > real:: a,x,bar
> > common /xx/ x
> > x=a
> > foo = bar(x)
> > end
> > Executing: gcc -o /var/folders/9w/7dlszmmn6q1gd5yf3r9n79bc0000gn/T/petsc-dk9aiv7x/config.setCompilers/libconftest.dylib -dynamiclib -single_module -undefined dynamic_lookup -multiply_defined suppress /var/folders/9w/7dlszmmn6q1gd5yf3r9n79bc0000gn/T/petsc-dk9aiv7x/config.setCompilers/conftest.o
> > Possible ERROR while running linker:
> > stderr:
> > ld: warning: object file (/var/folders/9w/7dlszmmn6q1gd5yf3r9n79bc0000gn/T/petsc-dk9aiv7x/config.setCompilers/conftest.o) was built for newer macOS version (11.2) than being linked (11.0)
> > Accepted FC PIC code without compiler flag
> > Its likely due to the way brew built gfortran. You can try compiling a simple test code and see if you can reproduce this warning.
> > There is a related issue at:
> > https://github.com/spack/spack/issues/21644
> > Satish
> > On Sat, 13 Feb 2021, Jacob Faibussowitsch wrote:
> >> Hello All,
> >> I’ve been getting these warnings for weeks, at first I figured it was due to gfortran brew package not being updated for Big Sur, but since it has persisted through a few gfortran brew updates I’m thinking it may be petsc related. This is on clean build on master.
> >> ld: warning: object file (master-arch-darwin-c-debug/obj/sys/classes/bag/f2003-src/fsrc/bagenum.o) was built for newer macOS version (11.2) than being linked (11.0)
> >> ld: warning: object file (master-arch-darwin-c-debug/obj/sys/f90-src/fsrc/f90_fwrap.o) was built for newer macOS version (11.2) than being linked (11.0)
> >> ld: warning: object file (master-arch-darwin-c-debug/obj/sys/objects/f2003-src/fsrc/optionenum.o) was built for newer macOS version (11.2) than being linked (11.0)
> >> ld: warning: object file (master-arch-darwin-c-debug/obj/sys/fsrc/somefort.o) was built for newer macOS version (11.2) than being linked (11.0)
> >> ld: warning: object file (master-arch-darwin-c-debug/obj/sys/f90-mod/petscsysmod.o) was built for newer macOS version (11.2) than being linked (11.0)
> >> Best regards,
