[petsc-dev] Fortran macOS Linkage Warning
Jacob Faibussowitsch jacob.fai at gmail.com
Mon Feb 15 10:41:15 CST 2021
I can reproduce the warning compiling just that simple code you listed. This is the compile command:
mkdir -p build && gfortran -c -o ./build/conftest.o conftest.F90 && gcc -o ./build/libconftest.dylib ./build/conftest.o -dynamiclib -undefined dynamic_lookup && rm -rf ./build
And error:
ld: warning: object file (./build/conftest.o) was built for newer macOS version (11.2) than being linked (11.0)
Note I recently uninstalled and reinstalled command line tools too, which does not seem to have fixed it.
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> On Feb 15, 2021, at 11:30, Satish Balay <balay at mcs.anl.gov> wrote:
> Here is the compile command and the warning:
> ===== Checking linker
> Executing: gfortran -c -o /var/folders/9w/7dlszmmn6q1gd5yf3r9n79bc0000gn/T/petsc-dk9aiv7x/config.setCompilers/conftest.o -I/var/folders/9w/7dlszmmn6q1gd5yf3r9n79bc0000gn/T/petsc-dk9aiv7x/config.setCompilers   /var/folders/9w/7dlszmmn6q1gd5yf3r9n79bc0000gn/T/petsc-dk9aiv7x/config.setCompilers/conftest.F90
> Successful compile:
> Source:
>      function foo(a)
>      real:: a,x,bar
>      common /xx/ x
>      x=a
>      foo = bar(x)
>      end
> Executing: gcc  -o /var/folders/9w/7dlszmmn6q1gd5yf3r9n79bc0000gn/T/petsc-dk9aiv7x/config.setCompilers/libconftest.dylib  -dynamiclib -single_module -undefined dynamic_lookup -multiply_defined suppress  /var/folders/9w/7dlszmmn6q1gd5yf3r9n79bc0000gn/T/petsc-dk9aiv7x/config.setCompilers/conftest.o
> Possible ERROR while running linker:
> stderr:
> ld: warning: object file (/var/folders/9w/7dlszmmn6q1gd5yf3r9n79bc0000gn/T/petsc-dk9aiv7x/config.setCompilers/conftest.o) was built for newer macOS version (11.2) than being linked (11.0)
>          Accepted FC PIC code without compiler flag
> Its likely due to the way brew built gfortran. You can try compiling a simple test code and see if you can reproduce this warning.
> There is a related issue at:
> https://github.com/spack/spack/issues/21644
> Satish
> On Sat, 13 Feb 2021, Jacob Faibussowitsch wrote:
>> Hello All,
>> I’ve been getting these warnings for weeks, at first I figured it was due to gfortran brew package not being updated for Big Sur, but since it has persisted through a few gfortran brew updates I’m thinking it may be petsc related. This is on clean build on master.
>> ld: warning: object file (master-arch-darwin-c-debug/obj/sys/classes/bag/f2003-src/fsrc/bagenum.o) was built for newer macOS version (11.2) than being linked (11.0)
>> ld: warning: object file (master-arch-darwin-c-debug/obj/sys/f90-src/fsrc/f90_fwrap.o) was built for newer macOS version (11.2) than being linked (11.0)
>> ld: warning: object file (master-arch-darwin-c-debug/obj/sys/objects/f2003-src/fsrc/optionenum.o) was built for newer macOS version (11.2) than being linked (11.0)
>> ld: warning: object file (master-arch-darwin-c-debug/obj/sys/fsrc/somefort.o) was built for newer macOS version (11.2) than being linked (11.0)
>> ld: warning: object file (master-arch-darwin-c-debug/obj/sys/f90-mod/petscsysmod.o) was built for newer macOS version (11.2) than being linked (11.0)
>> Best regards,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210215/44d3e4e6/attachment.html>
