[petsc-dev] Hypre error on updated Perlmutter
Paul Lin
paullin at lbl.gov
Fri Dec 10 09:39:25 CST 2021
Hi Mark,
Regarding the error:
"PETSC ERROR: cuda error 46 (cudaErrorDevicesUnavailable) : all
CUDA-capable devices are busy or unavailable"
how are you requesting a perlmutter compute node?
thanks
-paul
On Fri, Dec 10, 2021 at 6:54 AM Mark Adams <mfadams at lbl.gov> wrote:
> And more Perlmutter weirdness.
> If I configure with the above CRAY_ACCEL_TARGET=nvidia80 I get this
> (configure.log) error. (some CUDA aware MPI related errors)
> But if I configure with CRAY_ACCEL_TARGET="" it gets into Kokkos and I get
> this configure2.log with:
> #error -- unsupported pgc++ configuration! Only pgc++ 18, 19 and 20 are
> supported!
> I have not seen this before.
> As far as the first problem, If I load the cudatoolkit, which they say you
> can do *or* set CRAY_ACCEL_TARGET=nvidia80 , the problems go away or maybe
> fails before it gets to the first error, but it fails.
> I get the configure3 error that has these old warnings, but I'm not sure
> why it failed exactly.
> This was sort of working yesterday. I did rebase today, but even when
> working this has been fragile.
> Any suggestions?
> Thanks,
> Mark
> On Thu, Dec 9, 2021 at 1:59 PM Mark Adams <mfadams at lbl.gov> wrote:
>> Well I found, accidentally, that turning CUDA aware MPI on with export
>> seems to have fixed this.
>> Not sure what is going on.
>> On Thu, Dec 9, 2021 at 11:21 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> I am getting this error. I have built this w/o hypre and the test are
>>> fine, including the CUDA tests.
>>> Any ideas?
>>> I notice that the tests use -dm_mat_type aijcusparse with hypre.
>>> Thanks,
>>> Mark
>>> 08:13 nid003929 adams/fix_mat_ex5k= perlmutter:~/petsc$ make
>>> PETSC_DIR=/global/homes/m/madams/petsc
>>> PETSC_ARCH=arch-perlmutter-opt-nvidia-cuda check
>>> Running check examples to verify correct installation
>>> Using PETSC_DIR=/global/homes/m/madams/petsc and
>>> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
>>> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>>> processes
>>> 1,5c1,70
>>> < lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
>>> < 0 SNES Function norm 0.0406612
>>> < 1 SNES Function norm 4.12227e-06
>>> < 2 SNES Function norm 6.098e-11
>>> < Number of SNES iterations = 2
>>> > [0]PETSC ERROR: --------------------- Error Message
>>> > [0]PETSC ERROR: GPU error
>>> > [0]PETSC ERROR: cuda error 46 (cudaErrorDevicesUnavailable) : all
>>> > [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>> shooting.
>>> > [0]PETSC ERROR: Petsc Development GIT revision:
>>> v3.16.1-442-gebb4a459f5 GIT Date: 2021-12-08 08:59:23 -0500
>>> > [0]PETSC ERROR: /global/u2/m/madams/petsc/src/snes/tutorials/./ex19 on
>>> a named nid003929 by madams Thu Dec 9 08:13:49 2021
>>> > [0]PETSC ERROR: Configure options --CFLAGS=" -g -DLANDAU_DIM=2
>>> -DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4 -mp=gpu" --CXXFLAGS=" -g
>>> -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4 -mp=gpu" --FFLAGS="
>>> -g -mp=gpu" --with-cc=cc --with-cxx=CC --with-fc=ftn
>>> --with-cudac=/opt/nvidia/hpc_sdk/Linux_x86_64/21.9/compilers/bin/nvcc
>>> --with-debugging=0 --download-hypre=1 --with-cuda=1 --with-cuda-arch=80
>>> --with-mpiexec=srun --with-batch=0 --download-p4est=1 --with-zlib=1
>>> --with-make-np=8
>>> --prefix=/global/cfs/projectdirs/m3904/petsc/current/perlmutter-opt-nvidia21.9
>>> > [0]PETSC ERROR: #1 initialize() at
>>> /global/u2/m/madams/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:70
>>> > [0]PETSC ERROR: #2 getDevice() at
>>> /global/u2/m/madams/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:360
>>> > [0]PETSC ERROR: #3 PetscDeviceCreate() at
>>> /global/u2/m/madams/petsc/src/sys/objects/device/interface/device.cxx:102
>>> > [0]PETSC ERROR: #4 PetscDeviceInitializeDefaultDevice_Internal() at
>>> /global/u2/m/madams/petsc/src/sys/objects/device/interface/device.cxx:266
>>> > [1]PETSC ERROR: --------------------- Error Message
>>> > [1]PETSC ERROR: GPU error
>>> > [1]PETSC ERROR: cuda error 46 (cudaErrorDevicesUnavailable) : all
>>> > [1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>> shooting.
>>> > [1]PETSC ERROR: Petsc Development GIT revision:
>>> > [1]PETSC ERROR: /global/u2/m/madams/petsc/src/snes/tutorials/./ex19 on
>>> > [1]PETSC ERROR: Configure options --CFLAGS=" -g -DLANDAU_DIM=2
>>> --with-make-np=8
>>> > [1]PETSC ERROR: #1 initialize() at
>>> > [1]PETSC ERROR: #2 getDevice() at
>>> > [1]PETSC ERROR: #3 PetscDeviceCreate() at
>>> > [1]PETSC ERROR: #4 PetscDeviceInitializeDefaultDevice_Internal() at
>>> > [1]PETSC ERROR: #5 PetscDeviceInitialize() at
>>> /global/u2/m/madams/petsc/src/sys/objects/device/interface/device.cxx:227
>>> > [1]PETSC ERROR: #6 PCCreate_HYPRE() at
>>> /global/u2/m/madams/petsc/src/ksp/pc/impls/hypre/hypre.c:2224
>>> > [1]PETSC ERROR: #7 PCSetType() at
>>> /global/u2/m/madams/petsc/src/ksp/pc/interface/pcset.c:84
>>> > [1]PETSC ERROR: #8 PCSetFromOptions() at
>>> /global/u2/m/madams/petsc/src/ksp/pc/interface/pcset.c:154
>>> > [1]PETSC ERROR: #9 KSPSetFromOptions() at
>>> /global/u2/m/madams/petsc/src/ksp/ksp/interface/itcl.c:356
>>> > [1]PETSC ERROR: #10 SNESSetFromOptions() at
>>> /global/u2/m/madams/petsc/src/snes/interface/snes.c:1113
>>> > [1]PETSC ERROR: #11 main() at ex19.c:150
>>> > [1]PETSC ERROR: PETSc Option Table entries:
>>> > [1]PETSC ERROR: -da_refine 3
>>> > [1]PETSC ERROR: -dm_mat_type aijcusparse
>>> > [1]PETSC ERROR: -dm_vec_type cuda
>>> > [0]PETSC ERROR: #5 PetscDeviceInitialize() at
>>> > [0]PETSC ERROR: #6 PCCreate_HYPRE() at
>>> > [0]PETSC ERROR: #7 PCSetType() at
>>> > [0]PETSC ERROR: #8 PCSetFromOptions() at
>>> > [0]PETSC ERROR: #9 KSPSetFromOptions() at
>>> > [0]PETSC ERROR: #10 SNESSetFromOptions() at
>>> > [0]PETSC ERROR: #11 main() at ex19.c:150
>>> > [0]PETSC ERROR: PETSc Option Table entries:
>>> > [0]PETSC ERROR: -da_refine 3
>>> > [0]PETSC ERROR: -dm_mat_type aijcusparse
>>> > [0]PETSC ERROR: -dm_vec_type cuda
>>> > [0]PETSC ERROR: -ksp_norm_type unpreconditioned
>>> > [0]PETSC ERROR: -nox
>>> > [0]PETSC ERROR: -nox_warning
>>> > [0]PETSC ERROR: -pc_type hypre
>>> > [0]PETSC ERROR: -snes_monitor_short
>>> > [0]PETSC ERROR: -use_gpu_aware_mpi 0
>>> > [0]PETSC ERROR: ----------------End of Error Message -------send
>>> entire error message to petsc-maint at mcs.anl.gov----------
>>> > [1]PETSC ERROR: -ksp_norm_type unpreconditioned
>>> > [1]PETSC ERROR: -nox
>>> > [1]PETSC ERROR: -nox_warning
>>> > [1]PETSC ERROR: -pc_type hypre
>>> > [1]PETSC ERROR: -snes_monitor_short
>>> > [1]PETSC ERROR: -use_gpu_aware_mpi 0
>>> > [1]PETSC ERROR: ----------------End of Error Message -------send
>>> > MPICH Notice [Rank 0] [job id 832277.2] [Thu Dec 9 08:13:50 2021]
>>> [nid003929] - Abort(97) (rank 0 in comm 0): application called
>>> MPI_Abort(MPI_COMM_WORLD, 97) - process 0
>>> > aborting job:
>>> > application called MPI_Abort(MPI_COMM_WORLD, 97) - process 0
>>> > MPICH Notice [Rank 1] [job id 832277.2] [Thu Dec 9 08:13:50 2021]
>>> [nid003929] - Abort(97) (rank 1 in comm 0): application called
>>> MPI_Abort(MPI_COMM_WORLD, 97) - process 1
>>> > aborting job:
>>> > application called MPI_Abort(MPI_COMM_WORLD, 97) - process 1
>>> > srun: error: nid003929: task 1: Exited with exit code 255
>>> > srun: launch/slurm: _step_signal: Terminating StepId=832277.2
>>> > slurmstepd: error: *** STEP 832277.2 ON nid003929 CANCELLED AT
>>> 2021-12-09T16:13:50 ***
>>> > srun: error: nid003929: task 0: Exited with exit code 255
>>> /global/homes/m/madams/petsc/src/snes/tutorials
>>> Possible problem with ex19 running with hypre, diffs above
>>> C/C++ example src/snes/tutorials/ex19 run successfully with cuda
>>> Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI
>>> process
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211210/f22678ce/attachment-0001.html>
