[petsc-dev] Kokkos build fail
Mark Adams mfadams at lbl.gov
Wed Dec 8 07:49:39 CST 2021
I am failing on OSX with openmpi. Kokkos is failing to build.
I seem to be using:
(conda_env) 08:46 1 adams/fix_mat_ex5k *= ~/Codes/petsc2$
/usr/local/Cellar/open-mpi/4.1.1_2/bin/mpicxx --version
Apple clang version 13.0.0 (clang-1300.0.29.3)
Target: x86_64-apple-darwin21.1.0
Thread model: posix
InstalledDir:
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin
Any ideas?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211208/0ebfca10/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211208/0ebfca10/attachment-0001.obj>
