[petsc-dev] building on Spock
    Matthew Knepley
    knepley at gmail.com
    Fri Aug 13 13:01:39 CDT 2021
On Fri, Aug 13, 2021 at 1:49 PM Mark Adams <mfadams at lbl.gov> wrote:
> I was building on Spock a few weeks ago, but am getting these errors now.
> I have a setup with this environment and get this error.
> Any ideas?
Here is the error:
Executing: cc  -o /tmp/petsc-6izfgpkr/config.setCompilers/conftest
-L/opt/rocm-4.2.0/lib -lhsa-runtime64 -L${ROCM_PATH}/lib -lamdhip64
-lhsa-runtime64  /tmp/petsc-6izfgpkr/config.setCompilers/conftest.o
Possible ERROR while running linker: exit code 1
stderr:
ld.lld: error: unable to find library -lmpi_gtl_hsa
clang-12: error: linker command failed with exit code 1 (use -v to see
invocation)
Linker output before filtering:
invocation)
Linker output after filtering:
invocation):
          Error testing C compiler: Cannot compile/link C with cc.
            Deleting "CC"
That -l look like it is put in directly by 'cc'. How does anything work on
that machine?
   Matt
> Thanks,
> Mark
>     module load craype-accel-amd-gfx908
>     module load rocm
>     module load emacs
>     module load zlib
>     module load autoconf automake libtool
>     ## These must be set before compiling so the executable picks up GTL
>     export PE_MPICH_GTL_DIR_amd_gfx908="-L/opt/cray/pe/mpich/8.1.4/gtl/lib"
>     export PE_MPICH_GTL_LIBS_amd_gfx908="-lmpi_gtl_hsa"
>     ## These must be set before running
>     export MPIR_CVAR_GPU_EAGER_DEVICE_MEM=0
>     export MPICH_GPU_SUPPORT_ENABLED=1
>     export MPICH_SMP_SINGLE_COPY_MODE=CMA
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210813/4d3a2e74/attachment.html>
