[petsc-dev] -info from just one process?
Mark Adams mfadams at lbl.gov
Thu Apr 22 11:14:53 CDT 2021
OK, so -info out.%p would do what I asked. Alas, what I really need it to
reduce the output with 128K processes.
On Thu, Apr 22, 2021 at 11:54 AM Pierre Jolivet <pierre at joliv.et> wrote:
> On 22 Apr 2021, at 5:33 PM, Jacob Faibussowitsch <jacob.fai at gmail.com>
> wrote:
> Not out of the box no. There is -info ::self which makes info only print
> from calls made on PETSC_COMM_SELF, but I don’t think that’s what you want.
> Best advice would be to print to a file and grep the file for any lines
> starting with the rank number you want.
> There is no need for grep, IMHO, just do -info file and then open file.%p
> Thanks,
> Pierre
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> On Apr 22, 2021, at 10:16, Mark Adams <mfadams at lbl.gov> wrote:
> Can I make -info only print from one process?
> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210422/8fa6b87e/attachment.html>
