[petsc-dev] -info from just one process?
Pierre Jolivet
pierre at joliv.et
Thu Apr 22 10:54:23 CDT 2021
> On 22 Apr 2021, at 5:33 PM, Jacob Faibussowitsch <jacob.fai at gmail.com> wrote:
> Not out of the box no. There is -info ::self which makes info only print from calls made on PETSC_COMM_SELF, but I don’t think that’s what you want. Best advice would be to print to a file and grep the file for any lines starting with the rank number you want.
There is no need for grep, IMHO, just do -info file and then open file.%p
Pierre
> Best regards,
> (Jacob Fai - booss - oh - vitch)
>> On Apr 22, 2021, at 10:16, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>> Can I make -info only print from one process?
>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210422/e6246813/attachment.html>
