[petsc-dev] [EXTERNAL] Re: building on Fugaku
    Sreepathi, Sarat
    sarat at ornl.gov
    Fri Apr 16 14:01:51 CDT 2021
It’s 48 cores but there are 4 NUMA domains (CMGs). So, you may want to experiment in hybrid mode (4x12 etc.) if possible.
-Sarat.
Sent: Friday, April 16, 2021 2:10 PM
To: petsc-dev <petsc-dev at mcs.anl.gov>
Cc: Satish Balay <balay at mcs.anl.gov>; Sreepathi, Sarat <sarat at ornl.gov>
Subject: Re: [petsc-dev] [EXTERNAL] Re: building on Fugaku
Sarat, is there anything special that you do for Kokkos - OpenMP?
Just set OMP_NUM_THREADS=48 ?
Also, I am confused about the number of cores here. Is 48 or 64 per node/socket?
On Fri, Apr 16, 2021 at 2:03 PM Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>> wrote:
Cool, I have it running too. Need to add Sarat's flags and test ex2.
On Fri, Apr 16, 2021 at 1:57 PM Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
Mark,
The following build works for me:
Satish
pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L "elapse=1:00:00" --sparam "wait-time=1200"
. /vol0004/apps/oss/spack/share/spack/setup-env.sh
spack load fujitsu-mpi%gcc
spack load gcc at 10.2.0<mailto:gcc at 10.2.0> arch=linux-rhel8-a64fx
./configure COPTFLAGS='-Ofast -march=armv8.2-a+sve -msve-vector-bits=512' CXXOPTFLAGS='-Ofast -march=armv8.2-a+sve -msve-vector-bits=512' FOPTFLAGS='-Ofast -march=armv8.2-a+sve -msve-vector-bits=512' --with-openmp=1 --download-p4est --download-zlib --download-kokkos --download-kokkos-kernels --download-kokkos-commit=origin/develop --download-kokkos-kernels-commit=origin/develop '--download-kokkos-cmake-arguments=-DBUILD_TESTING=OFF -DKokkos_ENABLE_LIBDL=OFF -DKokkos_ENABLE_AGGRESSIVE_VECTORIZATION=ON' --download-cmake=https://github.com/Kitware/CMake/releases/download/v3.20.1/cmake-3.20.1.tar.gz  --download-fblaslapack=1
make PETSC_DIR=/vol0004/ra010009/a04201/petsc.z PETSC_ARCH=arch-linux-c-debug all
To test - redo job allocation using max-proc-per-node:
login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L "elapse=1:00:00" --sparam "wait-time=1200" --mpi "max-proc-per-node=16"
[a04201 at c31-3201c petsc.z]$ . /vol0004/apps/oss/spack/share/spack/setup-env.sh
[a04201 at c31-3201c petsc.z]$ spack load fujitsu-mpi%gcc
[a04201 at c31-3201c petsc.z]$ spack load gcc at 10.2.0<mailto:gcc at 10.2.0> arch=linux-rhel8-a64fx
[a04201 at c31-3201c petsc.z]$ make check
Running check examples to verify correct installation
Using PETSC_DIR=/vol0004/ra010009/a04201/petsc.z and PETSC_ARCH=arch-linux-c-debug
C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes
C/C++ example src/snes/tutorials/ex3k run successfully with kokkos-kernels
Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI process
Completed test examples
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210416/64a8dd60/attachment.html>
