[petsc-dev] [EXTERNAL] Re: building on Fugaku
Mark Adams mfadams at lbl.gov
Fri Apr 16 13:03:39 CDT 2021
Cool, I have it running too. Need to add Sarat's flags and test ex2.
On Fri, Apr 16, 2021 at 1:57 PM Satish Balay via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> Mark,
> The following build works for me:
> Satish
> pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L "elapse=1:00:00"
> --sparam "wait-time=1200"
> . /vol0004/apps/oss/spack/share/spack/setup-env.sh
> spack load fujitsu-mpi%gcc
> spack load gcc at 10.2.0 arch=linux-rhel8-a64fx
> ./configure COPTFLAGS='-Ofast -march=armv8.2-a+sve -msve-vector-bits=512'
> CXXOPTFLAGS='-Ofast -march=armv8.2-a+sve -msve-vector-bits=512'
> FOPTFLAGS='-Ofast -march=armv8.2-a+sve -msve-vector-bits=512'
> --with-openmp=1 --download-p4est --download-zlib --download-kokkos
> --download-kokkos-kernels --download-kokkos-commit=origin/develop
> --download-kokkos-kernels-commit=origin/develop
> '--download-kokkos-cmake-arguments=-DBUILD_TESTING=OFF
> -DKokkos_ENABLE_LIBDL=OFF -DKokkos_ENABLE_AGGRESSIVE_VECTORIZATION=ON'
> --download-cmake=
> https://github.com/Kitware/CMake/releases/download/v3.20.1/cmake-3.20.1.tar.gz
> --download-fblaslapack=1
> make PETSC_DIR=/vol0004/ra010009/a04201/petsc.z
> PETSC_ARCH=arch-linux-c-debug all
> To test - redo job allocation using max-proc-per-node:
> login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L
> "elapse=1:00:00" --sparam "wait-time=1200" --mpi "max-proc-per-node=16"
> [a04201 at c31-3201c petsc.z]$ .
> [a04201 at c31-3201c petsc.z]$ spack load fujitsu-mpi%gcc
> [a04201 at c31-3201c petsc.z]$ spack load gcc at 10.2.0 arch=linux-rhel8-a64fx
> [a04201 at c31-3201c petsc.z]$ make check
> Running check examples to verify correct installation
> Using PETSC_DIR=/vol0004/ra010009/a04201/petsc.z and
> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes
> C/C++ example src/snes/tutorials/ex3k run successfully with kokkos-kernels
> Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI process
> Completed test examples
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210416/392cc198/attachment.html>
