[petsc-dev] CI error
    Satish Balay
    balay at mcs.anl.gov
    Mon Apr 12 08:06:47 CDT 2021
This job gets run on either pj01 or pj02 - each have slightly different version of gcc. (and they behave differently wrt certain warnings)
[trade-off with diversity in testing and having redundancy in  available work machines - so jobs are not stuck on a single box]
I  guess I should somehow fix this (perhaps switch them all to same OS/versions].
Satish
On Sun, 11 Apr 2021, Mark Adams wrote:
> This warning went away. i don't know why.
> On Sun, Apr 11, 2021 at 2:10 PM Mark Adams <mfadams at lbl.gov> wrote:
> > I get this error in CI with complex float:
> > https://gitlab.com/petsc/petsc/-/jobs/1170144554
> > I put in code earlier to fix this warning about uninitialized vars, but
> > now it does not seem to work:
> > /home/glci/builds-stage1/AbTGp5-t/0/petsc/petsc/src/ts/utils/dmplexlandau/plexland.c:414:94:
> > error: ‘col_scale[4]’ may be used uninitialized in this function
> > [-Werror=maybe-uninitialized]
> > 2251 <https://gitlab.com/petsc/petsc/-/jobs/1170144554#L2251> PetscScalar
> > vals[LANDAU_MAX_Q_FACE*LANDAU_MAX_Q_FACE],row_scale[LANDAU_MAX_Q_FACE],col_scale[LANDAU_MAX_Q_FACE];
> > Yet I have code to initialize col_scale:
> >         for (q = 0; q < LANDAU_MAX_Q_FACE; q++) col_scale[q] = 0.0; //
> > suppress warnings
> > I get a similar error with an integer array.
> > Any suggestions?
