[petsc-dev] CI error
    Jacob Faibussowitsch
    jacob.fai at gmail.com
    Sun Apr 11 21:37:35 CDT 2021
> It did seem to be non-deterministic. (how is that possible?).
It can be a combination of the following:
1. Undefined behavior.
2. Dragons leaked from the undefined behavior.
3. In order to have 100% accuracy for detecting variable initializations the compiler must solve the halting problem, so compilers just silently give up after a certain point.
For an example of UB skipping those checks, suppose you have the following:
int func(int x)
  int y;
  If (x) return y;
  return 0;
For reasonable optimization levels this function will __always__ return 0, see for yourself https://godbolt.org/z/z4bxTa43x <https://godbolt.org/z/z4bxTa43x>  this is done on the same compiler and relevant options as the CI job you had. And best part is, gcc never complains about uninitialized y!
Now if such a piece was thousands of lines deep, and obfuscated by many different optimization transformations (such as arbitrary branch predictions, etc), then the compiler may or may not get around to determining whether this value was initialized.
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> I got this error, sent my message.
> Tried Barry's idea and initialized them all (5) by hand.
> It worked!
> I tried initializing just one.
> It worked.
> I tried initializing none (yes, back to where I started)
> And it worked :o
> I guess this error is another try-it-again CI error.
> On Sun, Apr 11, 2021 at 8:06 PM <jacob.fai at gmail.com <mailto:jacob.fai at gmail.com>> wrote:
> I ran into a similar problem months ago and the long and short of it is that any compilers uninitialized variable detection is incredibly dependent on optimization level, which the higher you go becomes non-deterministic.
> That being said, gcc is pretty terrible at getting this particular warning right :) https://gcc.gnu.org/bugzilla/buglist.cgi?quicksearch=may%20be%20uninitialized <https://gcc.gnu.org/bugzilla/buglist.cgi?quicksearch=may%20be%20uninitialized>
> Best regards,
> From: petsc-dev <petsc-dev-bounces at mcs.anl.gov <mailto:petsc-dev-bounces at mcs.anl.gov>> On Behalf Of Barry Smith
> Sent: Sunday, April 11, 2021 17:51
> To: Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>>
> Cc: For users of the development version of PETSc <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>>
> Subject: Re: [petsc-dev] CI error
>   You might be able to do:
> col_scale[LANDAU_MAX_Q_FACE = {0};
> but then the compiler may complain about not initializing enough values. Googling this type of initialization might help, something C initialize arrays "may be used uninitialized"
> On Apr 11, 2021, at 2:05 PM, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> This warning went away. i don't know why.
> On Sun, Apr 11, 2021 at 2:10 PM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> I get this error in CI with complex float:  https://gitlab.com/petsc/petsc/-/jobs/1170144554 <https://gitlab.com/petsc/petsc/-/jobs/1170144554>
> I put in code earlier to fix this warning about uninitialized vars, but now it does not seem to work:
> /home/glci/builds-stage1/AbTGp5-t/0/petsc/petsc/src/ts/utils/dmplexlandau/plexland.c:414:94: error: ‘col_scale[4]’ may be used uninitialized in this function [-Werror=maybe-uninitialized]
> 2251 <https://gitlab.com/petsc/petsc/-/jobs/1170144554#L2251> PetscScalar vals[LANDAU_MAX_Q_FACE*LANDAU_MAX_Q_FACE],row_scale[LANDAU_MAX_Q_FACE],col_scale[LANDAU_MAX_Q_FACE];
> Yet I have code to initialize col_scale:
>         for (q = 0; q < LANDAU_MAX_Q_FACE; q++) col_scale[q] = 0.0; // suppress warnings
> I get a similar error with an integer array.
> Any suggestions?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210411/3b5707e1/attachment-0001.html>
