[petsc-dev] CI error
jacob.fai at gmail.com jacob.fai at gmail.com
Sun Apr 11 19:06:53 CDT 2021
I ran into a similar problem months ago and the long and short of it is that any compilers uninitialized variable detection is incredibly dependent on optimization level, which the higher you go becomes non-deterministic.
That being said, gcc is pretty terrible at getting this particular warning right :) https://gcc.gnu.org/bugzilla/buglist.cgi?quicksearch=may%20be%20uninitialized
Best regards,
Jacob Faibussowitsch
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
From: petsc-dev <petsc-dev-bounces at mcs.anl.gov> On Behalf Of Barry Smith
Sent: Sunday, April 11, 2021 17:51
To: Mark Adams <mfadams at lbl.gov>
Cc: For users of the development version of PETSc <petsc-dev at mcs.anl.gov>
Subject: Re: [petsc-dev] CI error
  You might be able to do:
col_scale[LANDAU_MAX_Q_FACE = {0};
but then the compiler may complain about not initializing enough values. Googling this type of initialization might help, something C initialize arrays "may be used uninitialized"
On Apr 11, 2021, at 2:05 PM, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov> > wrote:
This warning went away. i don't know why.
On Sun, Apr 11, 2021 at 2:10 PM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov> > wrote:
I get this error in CI with complex float:  https://gitlab.com/petsc/petsc/-/jobs/1170144554
I put in code earlier to fix this warning about uninitialized vars, but now it does not seem to work:
/home/glci/builds-stage1/AbTGp5-t/0/petsc/petsc/src/ts/utils/dmplexlandau/plexland.c:414:94: error: ‘col_scale[4]’ may be used uninitialized in this function [-Werror=maybe-uninitialized]
 <https://gitlab.com/petsc/petsc/-/jobs/1170144554#L2251> 2251 PetscScalar vals[LANDAU_MAX_Q_FACE*LANDAU_MAX_Q_FACE],row_scale[LANDAU_MAX_Q_FACE],col_scale[LANDAU_MAX_Q_FACE];
Yet I have code to initialize col_scale:
        for (q = 0; q < LANDAU_MAX_Q_FACE; q++) col_scale[q] = 0.0; // suppress warnings
I get a similar error with an integer array.
Any suggestions?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210411/5dc76720/attachment-0001.html>
