[petsc-dev] -with-kokkos-cuda-arch=AMPERE80 nonsense
Tue Apr 6 13:44:30 CDT 2021
On Tue, Apr 6, 2021 at 2:08 PM Scott Kruger <kruger at txcorp.com> wrote:
> I wrote sent this yesterday but am having some strange mailing issues.
> On 2021-04-03 22:42, Barry Smith did write:
> >   It would be very nice to NOT require PETSc users to provide this flag,
> how the heck will they know what it should be when we cannot automate it
> ourselves?
> >   Any ideas of how this can be determined based on the current system?
> NVIDIA does not help since these "advertising" names don't seem to
> trivially map to information you can get from a particular GPU when you
> logged into it. For example nvidia-smi doesn't use these names directly. Is
> there some mapping from nvidia-smi  to these names we could use? If we are
> serious about having a non-trivial number of users utilizing GPUs, which we
> need to be for future, we cannot have this absurd demands in our
> installation process.
> The mapping of the Nvidia card to the gencodes and cuda arch is one of
> those annoyances that is so ridiculous it is hard to believe.
> The best reference I have found is this:
> https://arnon.dk/matching-sm-architectures-arch-and-gencode-for-various-nvidia-cards/
> To this end, the fact that Kokkos provides a mapping from colloquial
> card name to gencode/arch is a real benefit and useful.  The problem is
> that this mapping is buried in their build system and lacks
> introspection.
> >   Barry
> > Does spack have some magic for this we could use?
> spack developed the archspec repo to abstract all of these issues:
> https://github.com/archspec/archspec
I do not love it. Besides the actual code (you can always complain about
code),
they do not really do any tests. They go look in a few places that data
should be.
We can do the same thing in probably 10x less code. It would be great to
actually
test the hardware to verify.
     Matt
> This is a *great* idea and eventually BuildSystem should incorporate it as
> the standard way of doing things; however, it is been focused mostly on
> the CPU issues, and is still under active development (my understanding
> is that the pulling it out of spack and getting those interop issues
> sorted out is tangled up in how spack handles dependencies and
> compilers).  It'd be nice if someone would go in and port the Kokkos gpu
> mappings to archspec as there is some great knowledge on these mapping
> buried in the Kokkos build system (not volunteering); i.e., translating
> that webpage to some real code (even if it is in make) is valuable.
> TL;DR:  It's a known problem with currently no good solution AFAIK.
> Waiting until archspec gets further along seems like the best solution.
> Scott
> P.S. ROCm has rocminfo which also doesn't solve the problem but is at
> least sane.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210406/e34764ba/attachment.html>
