[petsc-dev] reminder on managing your merge requests MR
    Barry Smith
    bsmith at petsc.dev
    Mon Sep 28 19:12:30 CDT 2020
   This is a reminder for everyone submitting MR.
   You are responsible to track the progress of the MR. Make sure you use the
     label workflow:review when you think it is ready to be reviewed for merge, add additional appropriate labels also
     assign some appropriate reviewers
     make sure it gets tested
     when you resolve the reviewer concerns (called threads) make sure you mark them as resolved
     Once the tests are clean and the MR has been approved
        -  change the workflow label to workflow: ready for merge
        - assign Satish and no one else to the MR.
  By following this workflow less MR will get "lost"
  Thanks
  Barry
  With the new documentation approach in place we'll provide more detailed information on submitting MR and even videos :-) soon.
